Loud swishing noise after crank pulley install
I got the crank pulley installed, everything was fine at first. Drove the car across country and now I have this loud swishing noise. I can hear it really good at idle seems like its coming from somewhere around the drive belts. Timing belt was changed 4 months ago. I need help, my headers seemed to be making a loud metallic sound at all rpm ranges, sometimes even when I'm going 5 mph did some research and I'm going to check the heat shield...My car sounds like a piece of shit...swish swish swish swish...add a little metalic noise and
Any help is greatly appreciated
Swishing, as in liquid swishing around or air? Either way, while the car is running, make sure that your power steering fluid resevoir isn't bubbling up like crazy. I had a liquid/air swishing sound, and there was a small air leak in the power steering system, that caused it to bubble up.
Not like air swishing...Something is wrong with the belts, I am going to check the tension on them...I guess swishing isn't a good way to explain it...more like wick...wick...wick... wick...wick at idle and I think I can hear it when I'm pressing on the gas, but I don't here it after I'm going over 25 mph or I get the car moving...It doesn't get louder when I hit the gas
VS#03
I too had the same problem, with the swishing noise. My mechanic inform me the belts where tad to tight, so I had to purchase slightly bigger belt.......so it will loosen the tension on the pulley. They belt size that was recommended for the 04 TL was a 060820, but I went up to 060825........and this remedied the problem.
Kevin
Kevin
