Little Help: Need to replace ABS Module
Old Mar 13, 2009 | 08:28 PM
bhurlbut's Avatar
hey all, a little while back my ABS /!\ VSA lights went on once my ABS module kicked the bucket. Acura wants $1,700 just for the part but I found this used one:
http://cgi.ebay.com/ebaymotors/01-02...05126001r31997
Anyone know of any instructions from a Helm's manual or something to do this myself correctly?
Old Mar 13, 2009 | 09:22 PM
BigLizard's Avatar
Moderator Alumnus
Check under the hood by the master cylinder, the ABS module should be right next to it (very close to the brake fluid reservoir too).
You should be able to do this by yourself. Just remember to bleed your brakes after you change out the ABS module so no air is in the system.
Old Mar 13, 2009 | 10:00 PM
bhurlbut's Avatar
HHHmmmmmm................so i'm thinking of a different part all together then. The master cylinder is on the driver's side by the firewall, i thought the thing i have to replace is the part in the link above. The Acura mechanic said it was a faulty ABS module. WTF?
Old Mar 14, 2009 | 07:52 AM
fuzzy02CLS's Avatar
The modulator unit is the thing on the passenger side near the passenger headlight with a bunch of hard lines running into it.
Are you 6 speed or auto? it's a different part because of VSA.
That eBay link is for the auto VSA version.
Replacement is straight easy. Just have to bleed the brakes after doing it.
Old Mar 14, 2009 | 09:37 AM
bhurlbut's Avatar
Yeah, I'm 5AT
Old Mar 14, 2009 | 01:13 PM
jproy's Avatar
MP90 uninstalled
I agree.
Old Mar 14, 2009 | 01:25 PM
jproy's Avatar
MP90 uninstalled
FYI,
I found the modulator for the auto new $1167
http://www.acuraoemparts.com/delray/...All&vinsrch=no
And here is the unit for the 6-speed new $744
Old Mar 14, 2009 | 01:30 PM
jproy's Avatar
MP90 uninstalled
They also have hundreds of them here between $600-60.
http://www.car-part.com/
mada51589
Jan 9, 2025 04:40 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
HeloDown
Sep 8, 2015 06:51 PM
Stu2414
Aug 30, 2015 07:30 PM
