Wetsanding Headlights Pics
Old Feb 14, 2009 | 10:02 PM
tnobori1's Avatar
Missing my
I just took the time to wetsand my headlights and thought I'd share the results. I highly recommend this process for anyone! I had a buddy help me out and we knocked it out in a little over an hour. I just used the DIY in the CL Info Link.
Old Feb 14, 2009 | 10:03 PM
GhettoNinja06's Avatar
Skuuuurrrrrt!
Great job on the wetsanding! Looks great.
Old Feb 14, 2009 | 10:08 PM
zac's Avatar
zac
Much better!
Old Feb 14, 2009 | 10:25 PM
tnobori1's Avatar
Missing my
Thanks!! It was well worth the time!
Old Feb 14, 2009 | 11:10 PM
xBlur's Avatar
wants mods
Haha, I was just about to make this same thread since I wetsanded my headlights today also.
Before:
After:
And yes, my car needs a wash.
Old Feb 14, 2009 | 11:21 PM
nspec_ya4's Avatar
Regional Coordinator (Texas)
wet sanding works great. hopefully u guys didnt buff it too much because heat from that will create micro cracks in the plastic.
Old Feb 14, 2009 | 11:33 PM
Batosai's Avatar
bye Acura, hello Toyota
this would bring a tear in his eye if the resident hazy plastic enthusiast (noah aka ner aka hey-suse aka nf3 etc etc etc) would see this
Old Feb 14, 2009 | 11:39 PM
Wes_R's Avatar
You guys don't forget to put a sealant or wax over your headlights cause in the top parts of the plastic there is a UV protectant. If you don't protect the plastic the haze is just gonna come back over time.
Old Feb 14, 2009 | 11:52 PM
xBlur's Avatar
wants mods
Rubbing compound
2 coats of polish
2 coats of wax
Old Feb 15, 2009 | 09:39 AM
AnthraciteBeast's Avatar
Just needs some polish to make it really clear, and protectant as someone mentioned
Old Feb 15, 2009 | 11:15 AM
DK Type S's Avatar
those look phenomenal. i can haz link to process write-up?
Old Feb 15, 2009 | 12:00 PM
tnobori1's Avatar
Missing my
xBlur Haha, I was just about to make this same thread since I wetsanded my headlights today also
Looks great man! I guess great minds think alike! LOL!
https://acurazine.com/forums/2g-cl-2001-2003-50/fresh-wash-wax-wetsanded-headlight-pics-484296/
I buffed them with Meguiar's Plast - X... Should I hit em with some wax?
Old Feb 15, 2009 | 01:41 PM
nf3d0149ab's Avatar
good job...
Which UV protectant is best...?
Old Feb 15, 2009 | 04:28 PM
fuzzy02CLS's Avatar
I tried this, Made a total mess of EVERYTHING!!! I just bought a new headlight. I scuffed my bumper as well. I used the 3m kit that has the different grits & the pads you put in a drill.
I had white slurry all over the engine & fenders & hood cause the stuff flew EVERYWHERE when the drill hit it.
Old Feb 15, 2009 | 04:44 PM
tnobori1's Avatar
Missing my
OUCH!! We did the sanding by hand. Used an orbital buffer to apply the Plast-X, but I did get a few scuffs on the bumper... hopefully I can buff that off.
Old Feb 15, 2009 | 07:25 PM
bhurlbut's Avatar
Thanks for using the 'ol writeup!
Every time I wetsand my CL-s, I mask the headlights all the way around to provide atleast a 5-inch border with masking/painter's tape. Looks good, by the way!
Old Feb 15, 2009 | 08:19 PM
Yea i used 3M Plastic Polish and then some wax. They ended up looking like new
Old Feb 15, 2009 | 10:22 PM
monkeybutt's Avatar
I did this before, but must have been too scared to sand hard and only used a 2000 grit. This time I hand sanded w/ 1000 then 2000, and an orbital buffer for the Plast-X. And to finish I used Menzerna Final Touch Glaze and a couple coats of Blackfire Wet Diamond for protection.
Did this on my '96 TL w/ the peeling/yellow headlights and now they look new from 3 ft. away. The forum saved me some bucks again as I was just looking on Ebay for headlight covers. Will do the CL-S tomorrow.
Old Feb 15, 2009 | 10:47 PM
DarkSithCL's Avatar
Be Strong AND Courageous!
wow...
Old Feb 16, 2009 | 04:16 AM
nf3d0149ab's Avatar
Old Feb 16, 2009 | 08:59 AM
SlickShiftNall6's Avatar
Quarantuning
In case anyone who doesn't know how to remove bumper and headlights to wetsand or clear them. Here is the most complete DIY write up on this site.
https://acurazine.com/forums/showthr...dlight+removal
When searching you get like 20 different threads, most have old or no pics. But reading this thread again has inspired me to finally do this. I want to remove the orange diffuser and clean up this haze that is starting to form on the top of my headlights. Good Luck to anyone else doing this it doesn't seem hard just time consuming.
Old Feb 16, 2009 | 11:55 AM
fuzzy02CLS's Avatar
Originally Posted by nf3d0149ab
Because of my accident, they only replaced 1 headlight. The other didn't match now. I tried to wetsand it & made complete mess, It did look better but still didn't match the new headlight on the other side. So I just bought a new headlight & replaced it myself.
Old Feb 16, 2009 | 12:55 PM
01RedCLS's Avatar
How much is a new headlight online?
Old Feb 16, 2009 | 01:38 PM
nf3d0149ab's Avatar
Oh, that's right.
Makes sense.
Old Feb 16, 2009 | 02:21 PM
jaysizzlecity's Avatar
B A N N E D
Yeah nice job....
Old Feb 17, 2009 | 01:09 PM
bigwerm187's Avatar
Str8 Home built
dam that looks clean was grit did u use to wet sand them...?
Old Feb 17, 2009 | 10:04 PM
Integra_drk's Avatar
x2
Old Feb 17, 2009 | 10:48 PM
tnobori1's Avatar
Missing my
Thanks! I just used the DIY from the info post. https://acurazine.com/forums/showthread.php?t=484296
Bhurlbut posted it. Read through it, but basically you use 800 grit, move up to 1000 grit then to 2000 grit. Then you need to polish it (I used Meguiar's PlastX). He's right when he says it's scary as hell at first, but it comes out fine.
Good luck!
Old Feb 18, 2009 | 02:32 AM
xBlur's Avatar
wants mods
I used the DIY from the TL side and just used 1000 and 2000 grit.
Originally Posted by TL_Fo_Life
Thanks for the comment's.
1st. 1500 grit- 10 minutes wet sanding
2nd. 2000 grit- 20 minutes wet sanding
(after the sanding you wont be able to see through the light at all, so dont worry)
3rd. 3M rubbing compound (rub it in hard, or use a buffer)
4th. Meg's Polish
5th. Meg's carnuba wax
You could start with 1000, 1500, then 2000 grit if the headlights have severe scratches or haze.
Old Feb 25, 2009 | 12:56 PM
bigwerm187's Avatar
Str8 Home built
dam i never thought you would use sand paper to fix the head light..lol.. Great amazeing job you guys did..lol... so how long does this stay..? when do they get nasty lookinig again..? i was useing mothers alumium polish and that would work for a good while like 2 weeks then they head lights started to get yellow again..lol..
Old Feb 25, 2009 | 07:28 PM
LUTHOR-CL's Avatar
Chapter Leader (NY/NJ)
Nice job fellas!
Old Feb 25, 2009 | 08:01 PM
ll1l2l1l2lll's Avatar
w202 on carlssons
yeah. i did mine and a friends. back to yellow i want to spray something on it but i don't know what.
Old Feb 26, 2009 | 12:24 PM
bigwerm187's Avatar
Str8 Home built
from what i can see to fix that is to do the wet sading and after your done shoot some clear coat to keep them shinyy.... i think that would work. how long did they last befor they turned yellow again...?
Old Mar 14, 2009 | 09:28 PM
Quarantuning
So im in the middle of doing this right now... Took headlights apart to clear orange diffuser and retro fit projectors. So now im wet-sanding them and would love to know if there is any uv protectant, clear coat or whatever to help keep the lights looking new for longer after I polish and wax.
Plus all I had around was 1000 and 2000 grit, is 600 really necessary. I did have a couple of dings, chips left after hitting the first headlight with the 1000 grit. anyway just looking for some feedback.
Old Mar 15, 2009 | 01:49 AM
EliteDemon's Avatar
The TARDIS is my
dont spray clearcoat/semi-permanent protectants over the way or it will just slide/wear off eventually.
always wax last
MrHeeltoe
20
Feb 23, 2023 01:54 PM
hashbrown
Feb 18, 2022 11:20 AM
08KBP_VA
Oct 22, 2019 01:55 PM
Mr.Tea
Oct 2, 2015 10:32 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
