Little Help: Need to replace ABS Module
hey all, a little while back my ABS /!\ VSA lights went on once my ABS module kicked the bucket. Acura wants $1,700 just for the part but I found this used one:
http://cgi.ebay.com/ebaymotors/01-02...05126001r31997
Anyone know of any instructions from a Helm's manual or something to do this myself correctly?
Moderator Alumnus
Check under the hood by the master cylinder, the ABS module should be right next to it (very close to the brake fluid reservoir too).
You should be able to do this by yourself. Just remember to bleed your brakes after you change out the ABS module so no air is in the system.
HHHmmmmmm................so i'm thinking of a different part all together then. The master cylinder is on the driver's side by the firewall, i thought the thing i have to replace is the part in the link above. The Acura mechanic said it was a faulty ABS module. WTF?
The modulator unit is the thing on the passenger side near the passenger headlight with a bunch of hard lines running into it.
Are you 6 speed or auto? it's a different part because of VSA.
That eBay link is for the auto VSA version.
Replacement is straight easy. Just have to bleed the brakes after doing it.
MP90 uninstalled
MP90 uninstalled
FYI,
I found the modulator for the auto new $1167
http://www.acuraoemparts.com/delray/...All&vinsrch=no
And here is the unit for the 6-speed new $744
MP90 uninstalled
They also have hundreds of them here between $600-60.
http://www.car-part.com/
mada51589
05-03-2022 08:54 PM
HeloDown
09-08-2015 06:51 PM
