Lightn'd Crank Pulley <PROBLEM>
Old Dec 3, 2006 | 08:02 PM
ROCKSTAR's Avatar
I GUESS IM AN ASSHAT
Exclamation Lightn'd Crank Pulley <PROBLEM>
I just got the crank pulley installed with the needed belts but they said it was a pretty tight fit. And now ONLY when its cold and I start the engine it theres a loud noise coming from where the pulley is, not to mention theres a slight knocking. But then warms up and dosnt do it anymore! Big differance in power though!!
*Could it just be new belts???
*Can anyone help me, I dont want to make problems worse???
..Mabey I should loosen it up a little....
Thank You
Old Dec 3, 2006 | 08:14 PM
ROCKSTAR's Avatar
I searched and this is differnt then any other problem!!!
Is it exspensive to replace the engine bearing if that goes out??????????
Old Dec 3, 2006 | 08:22 PM
CL Platano's Avatar
Tristate ViP Crew
which setup did you get? Did you try loosening the belt?
Old Dec 3, 2006 | 08:40 PM
ROCKSTAR's Avatar
The bomz racing pulley... It works great besides that noise thats scaring me...
Isnt it an auto tensioner? How do I loosen it?
Old Dec 3, 2006 | 10:05 PM
Lord Helmet's Avatar
I'm here in spirit...
Sounds to me like it needs to be tightened, not loosened. Sounds typical of a loose belt.
Old Dec 3, 2006 | 11:21 PM
ROCKSTAR's Avatar
How have you been Lord Helmet?
Yeah its weird, she just makes that noise when its cold, but the power that it released is not huge but its noticable...II just hope nothing is wrong
Old Dec 4, 2006 | 06:04 AM
BigLizard's Avatar
Moderator Alumnus
tighten your belt, and check to see if your auto tensioner is faulty so you can get it replaced if needed. call your dealership and give them your VIN: they'll let you know.
acuratl26
Apr 23, 2020 07:30 PM
Jul 16, 2017 07:33 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
