LED's blinking fast??????
Old Jul 25, 2003 | 12:22 AM
azzkiker23's Avatar
i just purchased some very nice LED's and put them in my front turn signals....the only problem with them is that they blink very fast. the arrow inside of the car as well as the lights outside of the car.....does anyone have any suggestions or thoughts to what could be causing the LED's to blink so fast????? thanx !
Old Jul 25, 2003 | 12:26 AM
YuppieCL's Avatar
Moderator Alumnus
it blinks fast cuz the car thinks u have a blown turnsignal lamp.
maybe the LED doesn't complete the circuit and is giving the car that indication.
Old Jul 25, 2003 | 12:56 AM
Manic's Avatar
Possibly correct in part. The LED will draw much less current than it's filament predecessor, maybe this leads the monitoring hardware to beleive there is a problem.
Old Jul 25, 2003 | 01:00 AM
DivinDude's Avatar
The flasher is set to respond to a certain current load .. if that load is reduced, it will flash differently to show a change in load (faster in this case). The LED's definately change the current load it is expecting ... therefore, changing the flash frequency.
Old Jul 25, 2003 | 01:15 AM
azzkiker23's Avatar
so what should i do to correct this???????
Old Jul 25, 2003 | 07:30 AM
beerknurd's Avatar
Busy Living
Use a resistor to step down the current. Do you have the rating information on the led's you bought?
Old Jul 25, 2003 | 12:02 PM
azzkiker23's Avatar
no.....should i just buy a few different kinds of resistors and see which ones work the best?????
Old Jul 25, 2003 | 12:32 PM
beerknurd's Avatar
Busy Living
i'd guess somewhere around 400-500 ohm resistor.
Old Jul 27, 2003 | 09:37 AM
KCPreki11's Avatar
Old Jul 28, 2003 | 12:10 PM
azzkiker23's Avatar
the guy at direct auto said i would need a 6 ohm 50 watt resistor....i just talked to him today
Mike Pilipenko
Mar 26, 2024 09:21 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
ripit
Sep 26, 2015 06:19 PM
eastcoastguy
Sep 23, 2015 06:29 AM
