LED Lisence Plate Light
#202
SOLD: 03 SSM CLS Auto
Only DIY i've made so far is for the radio face. That one's pretty straight forward with what needs to be done. The gauges on the other hand are quite a bit more trial and error, unfortunately. Though, I have had excellent results recently using only single LEDs wired in parallel, and hot glued to the backs of the gauge faces. Than I solder the positive and negative leads from the entire set into the stock bulb holders (without any replacement bulb) and stick them back into their sockets. That description really makes it sound easy, but it's a very labor intensive process and can be quite tedious at times.
#203
i know this might be a stretch..but does anyone have a short video of LED tails? i really like the instant on/off look of them....but considering the wiring involved...i just want to make sure its worth it
also have you guys seen the new cadillacs reverse lights? they are some bright ass led's and look great!
im doing that next!
im doing that next!
#204
im doing that next!
im doing that next!
http://www.acura-cl.com/forums/showt...ghlight=LED%2A
#208
01 Type-S, Sexy Silver
I was thinking of getting the 5-LED Bulbs from superbrightleds.com (4 LEDs radially up down left right and one LED forward) for the front road lamps. Think these would look better or just a single LED.
Also, would the over-sized brighter high-power LED fit in the space for the license plate light?.
Referring to the 921-x12 or T13 LEDs on this page http://www.superbrightleds.com/mini-wedge.html
Input on Ultraviolet LED color?
#209
Just got my LEDs in yesterday and put them in everywhere (map lights, dome lights, courtesy lights, license plate, trunk, and my favorite: Front road lamps)... Got the 5-LED bulbs for the front (4 pointed around and 1 forward) and they're amazing. Light up the whole housing a lot better than any other setup I've tried.
Anyone else considering getting LEDs for the front road lamps, DEFINITELY go with the radially mounted 5-LED bulbs.
#214
Originally Posted by notorious7182002
anyone have any tips or info on installing the load resistors with the LED reverse, turns, and tails???
Originally Posted by CL-Slick
Is it legal to get dark blue ones?
#215
Seton Hall Pirate
[QUOTE=gaping46and2]Cut the positive wire running to the bulb, solder in the resistor. Repeat for each bulb.=QUOTE]
K I know nothing about this whole solder business. what kind of automotive shop would do this for me?
#216
Unregistered user
[QUOTE=notorious7182002]
really not that hard, i wouldn't pay anyone to do this for me... if you can't do it just buy a bulb that fits its definately not worth it.
or go on youtube search, and follow their directions its really not that hard.
#217
Watch this, and read this, and this, and more videos for your viewing pleasure. Those will help you tremendously, and just about anyone else wanting to know more about soldering in general.
#226
I purchased a Blue, 5 LED, 3 Chip (Very Bright) Oracle LED for my license plate. This bulb is so bright that it produced a glow 3 feet in depth covering pretty much the entire length of my bumper. I never got picked up for it, but I happened to be talking to an officer one day and asked him if the LED was legal/would cops bother me for it. He replied saying he was surprised that I had not got picked up for it yet. When I found out the fine was about $150 I swapped it out with a White, 5 LED, 3 Chip Oracle LED. This LED is just as bright as my first one, but not blue like I originally wanted.
Currently I have 7 color changing LEDs throughout my whole interior (maps, dome, doors, ect.). I am goin' 2 swap them out with blue Oracle LEDs because I have never seen LEDs so damn bright before! Here's the link for the Oracle LEDs: http://www.automotivelightstore.com/...S&Category=902
#231
I put in the EXLED kit today and after driving around the lisence plate lights were off...I'd there a breaker?? This is on a 2010 tsx I just got...they flickered a bit on installation..trying to figure this out
#232
you guys have to be careful with exterior lighting. If it isn't the correct color, you can be ticketed and even towed. Generally red and blue are reserved for emergency vehicles.. also if your lighting fixtures are not DOT approved, you can be towed. (ie you put HID kit in a non HID equipped car - ever wonder why most if not all of the actual kits (not the seller website) they say off road use only?)
#233
^yea you def have to watch with the colors. i changed my road lamps to blue leds and my buddy has purple hids in his and ive been the unlucky one who got caught and ticketed for them.
a good led mod to do that weve done to ours is the turn signals. theyre yellow while theyre on and then flash with the turn signal. we replaced them with led bulbs that are white while running and change to flashing amber when you put your signal on. there is also another 194 bulb in the small yellow housing under the signal bulb. just pop that one out completely and it makes your headlights one solid color unless your signal is on. looks so much better in my opinion
#234
2003 Acura CL-S6
I know this is a old thread but I have some LEDS I want to use for my license plate but I can't figure out how to get the damn thing out... Its a long clear plastic piece. Any help?
#236
2003 Acura CL-S6
Can anyone post a pic of these screws? I didn't spend to much time looking at it. I also only have 1 LED it looks like the assembly has a strip of bulbs?
rockyboy
08-04-2024 10:35 AM
oyayjoe
09-12-2015 04:40 PM
drewdeezy03
09-03-2015 08:04 PM
