Leak?
Old Aug 13, 2004 | 12:28 AM
FunkeeTown's Avatar
friend of fast
Leak?
what can leak orange under in our engine? i looked on the left side of the engine bay and there was orange fluid spilled everywhere? any idea what that might be?
also my car kinda shakes at idle? has anyone experienced that before? could it be timing belt or what? it's not bad but you can feel it when in park. ya'll help me out. please.
Old Aug 13, 2004 | 12:46 AM
Red-CL's Avatar
Doin' da crack shuffle
Orange?
I know some antifreezes are orange. Have you checked that yet?
I would check all the fluids to be on the safe side.
Old Aug 13, 2004 | 12:53 PM
BC2G's Avatar
Registered Big Dog
um ... kool aid
Old Aug 13, 2004 | 01:07 PM
EricL's Avatar
ARE you sure it isn't ATF? It would be more of a reddish/orange color (or brown if it was really cooked off).
If you have it on the driver's side and depending on what your calling orange, it could be ATF.
If not, then check this out (from http://www.prenhall.com/autoweb/techtips/automatic.html)
What's leaking?
The color of the leaks observed under a vehicle can help the technician determine and correct the cause. Some leaks such as condensate (water) from the air conditioning system are normal, whereas a brake fluid leak is very dangerous. The following are colors of common leaks:
Sooty black -- engine oil
Yellow -- antifreeze (engine coolant)
Green -- antifreeze (engine coolant)
Blue -- antifreeze (engine coolant)
Orange-- antifreeze (engine coolant)
Red -- automatic transmission fluid (ATF)
Murky brown -- brake or power steering fluid or very neglected antifreeze (coolant)
Clear -- air conditioning condensate (water) (normal)
Old Aug 13, 2004 | 01:15 PM
FunkeeTown's Avatar
friend of fast
it's on the passanger side...if you're looking at it when you pop the hood it's right where the belts are or a little on the left. kinda on the wheel bay. it's definitely orange, i don't know what the hell...maybe the mechanic who installed my springs spilled some kool aid inside and forgot to wipe it off.
any idea about the vibration? only happens at park at idle?
Old Aug 13, 2004 | 01:22 PM
EricL's Avatar
Can you just check the various resevoirs under the hood (like coolant, power steering, etc) and check the color you wipe off and the level.
Not sure about shake... Only at idle ... possibly the motor mount or related control system...
Old Aug 15, 2004 | 08:55 PM
FunkeeTown's Avatar
friend of fast
i guess maybe i have an antifreeze leak. gotta go to dealership and check it out tomorrow. thanks for all the suggestions.
Old Aug 15, 2004 | 09:02 PM
VeeralS05's Avatar
I NEED MONEY!
be careful driving...we gotta watch out for our fellow CLer's
Old Aug 15, 2004 | 10:23 PM
Ant7701's Avatar
Sweet as Gold
does ur CL have that orange windshield washer fluid from RainX???If not the u might be color blind
Old Aug 16, 2004 | 01:00 AM
Chopsie's Avatar
Beware of leakage
we have the green coolant
Old Aug 16, 2004 | 08:06 AM
NOLACLS's Avatar
I thought my wifes car was leaking something red in the garage one time. Upon further inspection by me I see a fawking can of red soda on the ground. It must have fallen, roled under her car and had a tiney pin hole in it.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
