Knock sensor and the Super Charger
Old Apr 15, 2005 | 07:20 AM
  #121
sohfast94's Avatar
Now check your Email... I know it worked this time.
Old Apr 15, 2005 | 09:15 AM
  #122
SCTL-SS's Avatar
13.68 @ 102.56
Originally Posted by 02AV6
Chemmech and SCTL-SS you guys are nuts
My wife would agree with you....and....I'm starting to believe it myself.
Originally Posted by sohfast94
Question: If oyu have the two additional injectors thhen why the FMU? The only reason the FMu would be untilized is because you don't have extra or "supplementary" injection. Being that you have that itr negates all logic of the FMU. In thhe broader spectrum the injctors are ony to support up to 43-7psi under noraml conditions. They are not rated for that high of a pressure especially not when it comes to consistency and longevity of the injector which is directly related to engine life becasue if you injector gets stuck open from running that much pressure then say GOOD BYE! That's why I gripe about FMU's and such. There's always a better way.
I really do like the idea of mo more FMU.
Old Apr 15, 2005 | 12:42 PM
  #123
Chemmech's Avatar
Haven't received any reply yet sohfast94, can you hook up on hotmail.com ?
Old Apr 15, 2005 | 03:48 PM
  #124
sohfast94's Avatar
One second it takes me a minute.
Old Apr 15, 2005 | 03:50 PM
  #125
sohfast94's Avatar
Did you get the file???
Old Apr 15, 2005 | 03:53 PM
  #126
sohfast94's Avatar
Alright I'm leaving work in ten minutes so give me about an hour and I'll send it to you again when I get home.
*edit* Page 6 Ownage... (Just had to do it)
Old Apr 15, 2005 | 03:57 PM
  #127
Chemmech's Avatar
Has this thread gotten just alittle of the topic? Hmm... knock sensors to injectors . Thanks sohfast94 for the tech support .
Old Apr 15, 2005 | 04:07 PM
  #128
Chemmech's Avatar
I'm being owned by Hotmail
Old Apr 18, 2005 | 10:47 AM
  #129
sohfast94's Avatar
Well did that file get you started or do you need further assistance? You're running the 550's rright? you shouldn't need the FMU becasue the 440's were just barely not enough for SCTL-SS's car so 550's should work just perfect... Unless I'm off my rocker again. You really should get a Wide-Band though. I'm a tuner and tuning without a wide-band is not recommended. Even if you have to go pay for some dyno time. I would. If you need I can help I don't know where you live though!
Old Apr 18, 2005 | 11:27 AM
  #130
Chemmech's Avatar
I live Hades (South Bay Area), California. Nofile yet, instead of hotmail, try this address vmax14@juno.com . No FMU? Would that be the same as just setting the values all to zero? I still need the E-manage to do boost cutting. Yeah I will really need to see a specialist, doing this all by feel is not a good idea. BTW, still waiting on the fuel pump, it's on back order :& I have everything else ready for the install.
Old Apr 18, 2005 | 12:00 PM
  #131
Chemmech's Avatar
OK, I just got the file (April fools) .
Old Apr 18, 2005 | 12:04 PM
  #132
Chemmech's Avatar
Very intersting #'s in the add. inj. Must have taken alot of time to get it down .
Old Apr 18, 2005 | 04:43 PM
  #133
mrsteve's Avatar
FMU = Fuel Pressure Regulator
I have the AEM Gauge-Type Wideband O2 sensor that I no longer need. Cost me $400. I only installed the gauge... never the sensor. $300 shipped to you.
Old Apr 19, 2005 | 07:08 AM
  #134
sohfast94's Avatar
Good deal take it. I just paid 600 for my PLX R-500 which will finally be released on the 25th of this month. www.plxdevices.com
Old Apr 19, 2005 | 11:24 AM
  #135
SCTL-SS's Avatar
13.68 @ 102.56
Maybe you can use that on my car when the time comes. Just waiting on another resurrected tranny.....
Old Apr 19, 2005 | 11:35 AM
  #136
Chemmech's Avatar
WTF, tranny went bad?
Old Apr 19, 2005 | 11:44 AM
  #137
Smitty's Avatar
oh O
Old Apr 19, 2005 | 02:21 PM
  #138
SCTL-SS's Avatar
13.68 @ 102.56
When it's cold doesn't like to shift into 2nd. Then D-5 flash, VSA,etc...all I have then is 3rd.
After warming up it's miserably talarable - very hard shifts into 2nd and 3rd. If it's WOT then it just "free revs". The only thing fun right now is burn-outs and WOT in 3rd gear on the highway. Every thing else in between is R.I.P.
ITSJESTER
17
Dec 6, 2018 02:29 AM
RobbDizzle
Oct 15, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
STL TL-S
Sep 23, 2015 08:52 PM
