Knock sensor and the Super Charger
Originally Posted by sohfast94
Sorry if some of this has went around in circles. But, this is after all "R&D" so it happens sometimes.
... Now as for the trac. control or the "VSA" you have to understand foist of all that SCTL-SS's car is a beast on the tires because the tire wear is directly related to your foot (or TPS%) So as you can see the VSA trys to combat that which I will not let that happen because it hinders the performance of the vehicle immensly. I have also found that if you manually shift it as in not using the shift-a-matic it will spin through third gear without effort. ...
We'll I put the 550's back in, and today is a different story from last week. With airflow adjustment made the cars idle Just Like Stock!!! The cars in my backyard, and being blocked in by my wifes car, so I can't take it out on the road, just yet. Anyway, I put the car into gear and floored it to about 4500 rpm, no hesitation at all. Last week the car wouldn't idle or rev up at all, but now it seems fine
!!! Thanks for the tips Sohfast94!
It seems that the car is streetable, and that's a really good place to start out, because last week it was getting way too much fuel.
I'll write again when I take it on the steet :evilgrin: .
We'll it runs alot better, but there are still fuel issues though (too much of it). Off boost and under acceleration the car stumbles alot. Arrggh! I guess I'll have to go with additional injection instead.
Originally Posted by Chemmech
what terminals get the resistors and how much resistance?
So wtf is happening, too much fuel all at once, timing being pulled, vsa acting up even though it doesn't light up??? it really starts to pull (the engine), then it just falls on its face
thanx for the info Type R
WTF "IS" Happening...
Do you have a wide band AFR? If so what does it say when this happens? What is the timing at this particular point in the map?
What is the fuel setting by the E-manage? Have you tried to log the injector duty cycle compared to the stock cycle? There many ways to interpret this which are you most comfortable with? I would sya I'm fairly versatile when it comes to this stuff. Do you have a stick or auto? Did I already ask you that? (Just keeping you on your toes) What's the fuel pressure at tip in? Or when you start to step on it. Do you have an FMU? If so take it off your injectors have enough to not need it. If you refer to my previous post I referneced you and the size of your injectors.
Auto, no fuel setting to the E-Manage, no wide band but I can see alot of brown smoke fro m the exhaust when it stumbles so it's def. too rich, no adj. to timing, 43 psi at tip in.
I just took the car out right now, unhooked the VSA and the engine was cold. That Biatch accelerated up to 80 mph in just a couple of heartbeats wow! But after the car warmed up, it was the same old story, stumbles on throttle tip in. There's definately alot of potential there.
I guess I need to go get some resistors now for the VSA.
Okay here's what happens. Basically when the car is cold it's running in open loop so it's basically "learning" at that point. Not making part throttle corrections based on the target AFR table in the stock ECU which is ~14.6-7:1 Once you pass ~70% TP It will not be relying on the O2 sensor anymore and will be utilizing what is commanded in the traget AFR from the ECU. The trick here is to get the fuel threshold from the E-manage to meet when it goes into open loop. The 14.6-7:1 is okay when not under boost I would rather lower but, that is what you have to work with right now. Oh yeah you have PM.
Yeah I did some fuel checks, the Walbro pump can't keep up with the 550's. I'm gonna upgrade the fuel system. That's why it would stumble, then go rich, the pump waz surging pretty bad and loosing pressure.
Oh yeah, vmax14@hotmail.com
Even though the car accelerated up to speed, it was still way lea up top.
I'm considering something kinda like this http://www.jegs.com//cgi-bin/ncommer...20&prmenbr=361 , total kit cost in the ballpark of $700.
http://216.242.145.16/products/product.phtml?p=4
Nice
! I'm gonna mount the pump, when I decide on which one, in my trunk, out in the open with alot of nice AN fittings to dress it up. I just hope the one I choose is quieter than the Mezier water pump I have runnin the IC system.
Nice
to really get fancy, and since your opting to use an aftermarket pump and larger injectors (and regardless of what some may think, for they have to think outside the norm, the guys running the extra injector, who will chime in) regardless of what argument they present, consider trying this. it may be pricey, but you have most of the power makers in place. Now to tune it properly. Take a look at this link.
use this
http://216.242.145.16/products/product.phtml?p=10
with this
http://www.bellengineering.net/Pages/products_FPR.html
Then, IMO you will have the proper hardware for fine tuning.
Yep, I will not be using any of the stock fuel system lines as they are about 5/16" in diameter, very restrictive. As for the pick up, I will be running a 6 AN size hose, as well as all the way to the front of the engine. A bulk head fitting and epoxy will be needed for the pickup. I think the fittings will run in the neighborhood of about $200, the hose about $80, the pump about $300, filters about $180, all around $750 total ( I know I can't add
). AN 6 is about what, 5/8" ? That should be more than adequate. Of course a reducer will be used for connecting the lines to the regulator. The fitting on the Comptech regulator is setup for 5/16", but I will be replacing it with a larger AN fitting.
Even with my current setup, stock injectors, E-manage, HBP, my system is lean and maxed out.
). AN 6 is about what, 5/8" ? That should be more than adequate. Of course a reducer will be used for connecting the lines to the regulator. The fitting on the Comptech regulator is setup for 5/16", but I will be replacing it with a larger AN fitting.Even with my current setup, stock injectors, E-manage, HBP, my system is lean and maxed out.
Must feed the monster more food, er I mean fuel !!! I freaked my friend out at work yesterday, he couldn't believe how fast the car accelerates
. I told him to wait till next week, 550's.
. I told him to wait till next week, 550's.I hope it's all good news, my monster is Ok as long as it doesn't have to shift.
Right now I'm back to the 270's. I put the 550's in last week to test it out. I haven't received the Map from Sohfast94 yet; however, I have been able to configure a Map that allowed the car to idle just fine, just like stock. It took putting in some negative values in the air flow adjustment to cut the fuel back. I just placed a big order today to get things rolling. I'll be expecting a big package from Jeg's soon
. I have to see what the safest mounting area for the pump is though.
Originally Posted by allmotor_2000
With 550cc, you shouldn't use a rising-rate FMU... just a regular FPR should do. 6x550cc at 100psi is a heck of a lot of fuel!
Yeah, I'm probably gonna end up getting a reular bypass regulator soon. I'm going to just unhook the vacuum line for now so I'll just be getting 43 psi to the injectors.
1 Russell Twist-Lok ''AN'' Hose Ends - -06AN Hose End
799-624340 $17.99 $17.99
7 Russell Twist-Lok ''AN'' Hose Ends - -06AN Hose End
799-624010 $5.49 $38.43
1 Jeg's ''AN'' Union Adapter & Reducer Fittings - -6 AN to -8 AN Flare Reducer
555-100212 $4.99 $4.99
1 Russell Hose Support Cushion Clamps - -06AN Cushion Clamps; 10/pkg
799-650980 $12.99 $12.99
799-624160 $11.99 $11.99
2 Jeg's ''AN'' Union Adapter & Reducer Fittings - -6 AN Flare Union
555-100202 $3.69 $7.38
1 Russell ''AN Male to AN Male Bulkhead'' Adapter Fittings & Nuts - -06AN Male to -06AN Male Bulkhead Fitting
Straight
Endura Finish
799-661181
$7.99 $7.99
1 Russell ''AN Male to AN Male Bulkhead'' Adapter Fittings & Nuts - -06AN Bulkhead Nut
9/16-18 Thread
Anodized Finish
799-661890
$4.69 $4.69
1 Jeg's ''AN'' Union Adapter & Reducer Fittings - -4 AN to -6 AN Flare Reducer
555-100211 $3.99 $3.99
1 Russell Twist-Lok Hose - -06AN
799-634160 $69.99 $69.99
1 Painless Wiring Electric Fuel Pump Relay - Fuel Pump Relay
764-50102 $26.99 $26.99
1 Aeromotive 800 HP EFI Fuel Pump - 700 HP EFI Fuel Pump 30 to 65 PSI
027-11106 $292.99 $292.99
2 System-1 Billet Aluminum Fuel Filters - Pro Street Inline Fuel Filter
-06 AN Ends
888-201406
$89.99 $179.98
That should do it
Straight
Endura Finish
799-661181
$7.99 $7.99
9/16-18 Thread
Anodized Finish
799-661890
$4.69 $4.69
-06 AN Ends
888-201406
$89.99 $179.98
That should do it
sohfast94 there must be a problem with the e-mail, I haven't received any messages on hotmail
The only message I have in my e-mail right now is from a billionare, Mr. Sipho, in south Africa trying to get me to help out with his mining export bussiness
I think for a ~700whp setup, a CL-S would need (for driveability and ease of tuning):
i. 6x370cc injectors
ii. Comptech FMU so that 15psi of boost increases fuel pressure to 85psi
iii. 2x750cc secondary injectors
I have a new set of six RC 750cc injectors if anyone is interested, email me at desijigga786@yahoo.com
Is this in your test plans???
Plan....
Question: If oyu have the two additional injectors thhen why the FMU? The only reason the FMu would be untilized is because you don't have extra or "supplementary" injection. Being that you have that itr negates all logic of the FMU. In thhe broader spectrum the injctors are ony to support up to 43-7psi under noraml conditions. They are not rated for that high of a pressure especially not when it comes to consistency and longevity of the injector which is directly related to engine life becasue if you injector gets stuck open from running that much pressure then say GOOD BYE! That's why I gripe about FMU's and such. There's always a better way.
No problem, I'm looking forward to it
