Just installed my ZEX Kit
Old Jun 13, 2002 | 03:10 PM
Paul750's Avatar
I just installed my new ZEX kit on my 01, CL-S.
I love it! I am running a 55 shot for now but to run a larger shot you have to retard the ignition. I also switched the plugs and a new fuel pump and fuel pressure regulator are on their way.
The performance is nice. Right now I have an Injen CAI and HKS draggers I also removed the center muffler and replaced it with a test pipe. Me and a friend installed the kit and it went very smoothly. But the spark plugs were a huge pain in the a**! Their is no space to work behind the engine. Anyway let's talk about how it performs! Off the line with line with the bottle off, and punching it would result in a little chirp and a constant pull, but with the bottle on, off the line accel. is much better. Punching it from a stop lights the tires up all the way to red line but not franticly, it still pulls, and then once in v-tech for 2nd. and 3rd it go's through the gears much faster! (while hearing a loud hissing sound the whole time). On the highway it is not as noticeable, doing the 3rd gear hit at 80 mph, you can still feel the difference but not nearly as much. I'm thinking because with the 55 shot I only added about 35 more hp to the ground. But off the line you can really feel the added torque.
Old Jun 13, 2002 | 03:21 PM
xenon7's Avatar
Xe- For Better Hwy Vision
Most bang for the buck, NO2 is the bomb!
You said you installed a new FR, is it adjustable? might be worth while now to check your set up on a dyno-jet and do some real time adjustments.
Expensive little habit you got there. Good luck with it, and post some pics PLEASE!!!
Old Jun 13, 2002 | 03:27 PM
Nicky Pass's Avatar
Fuct in the hed!
BE CAREFUL.........don't get spray happy...........GOOD LUCK
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
Good luck with the tranny!
Old Jun 13, 2002 | 04:38 PM
edgalang's Avatar
Purchased: April 28, 2001
I forgot if it was ZEX or maybe Nx that advertised that 1 shot = 1 WHP. Anyways...what is the largest dry shot you can put in without changing ANYTHING else?
Old Jun 13, 2002 | 04:52 PM
xenon7's Avatar
Safe bet is the 25shot- very conservative. But still...........I would be careful with whatever, its all about mixtures and PPM. That's why I asked about that adj. FR.
Old Jun 13, 2002 | 05:03 PM
SFLA_Type-S's Avatar
Sold 12/29/04 :-(
Welcome to the ZEX Family...
Old Jun 13, 2002 | 05:37 PM
SiGGy's Avatar
Moderator Alumnus
Re: Just installed my ZEX Kit
Just need some headers now! (you don't have a sig, I assume you would have mentioned them if you had them) Imagine another 25 +/- 5hp at the wheels too
Keep us posted on your results from that stuff!
Black CL-S 4-Life's Avatar
Floyd Mayweather Jr.
Congrats now take her to the track.
Old Jun 13, 2002 | 05:40 PM
SiGGy's Avatar
Moderator Alumnus
Depends on your factory fuel pump/injectors, no matter what your going to need a wet system if you want 100+ shot. (unless your crazy, or just ignorant)
I wouldn't push much past a 50 shot with a factory fuel pump. But some vehicles are capable of a 100 dry shot with EOM parts.
I think the N2O site will help fill any other question gaps you might have.
Old Jun 13, 2002 | 07:08 PM
DigiBox's Avatar
Lots of JDM parts on my
NX has a kit that claims 50HP at the wheels. I seen an install on it along with a dyno. It didn't hit the 50hp until a bottle warmer was added. I gained 30HP at the wheels without the warmer with the 55 shot. Most cases, the warmer adds another 10HP. I could only imagine the kick it gives a CL-S
Old Jun 13, 2002 | 07:23 PM
edgalang's Avatar
Crazy no...but definitely ignorant when it comes to spraying. I am starting to humor my fantasy of the possibility...but at the same time dont want to replace anything that is OEM. From what I've read, 50 shot is usually the biggest you can go if you want to run all stock.
Old Jun 13, 2002 | 07:44 PM
WiLd~CL~TYPS-@SS's Avatar
I love my CL-S
what's the minmium shot i can use? how much for the whole kit??
Old Jun 13, 2002 | 09:48 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Yeah, welcome!
WiLd~CL~TYPS-@SS: I got my kit for $580 shipped, including pressure gauge and purge kit off of eBay. Bought the plugs for around $28.00, shipped! Got a bottle warmer for $75.00, shipped.
Old Jun 13, 2002 | 11:38 PM
I love my CL-S
Originally posted by dustbuster4
Yeah, welcome!
so how do you choose how many shots you want??
thanks
Old Jun 14, 2002 | 12:03 PM
blackmagic's Avatar
1st, its N2O not NO2
2nd, the zex kit comes with jets, for fuel and for nitrous, you pair up these jets with the sizes listed in the book to show you what shot you're running, this limits the flow of nitrous and adds the correct amount of fuel to the injectors.
you could run a 65 shot without retarding the timing...and maybe the 75 if you have good gas...say 94 octane...
the engine will easily hold a 75 shot, it is a V6...so the nitrous per cylinder is less when compared to other honda engines (4 cylinders that is)
the tranny is another story...that i'd beware of
i would also get the headers...its always a good idea to have a free flowing intake/exhaust system when using a larger shot of nitrous
Old Jun 14, 2002 | 12:05 PM
blackmagic's Avatar
also, don't put an adjustable FPR on the engine unless you have some good tuning equipment to monitor a/f ratio...and an autometer a/f guage does not count as GOOD tuning equipment
Old Jun 14, 2002 | 12:20 PM
I love my CL-S
thanks for the info blackmagic
Old Jun 14, 2002 | 06:13 PM
Chaptorial's Avatar
Depe
Does anyone else find it funny that they're selling copies of The Fast and the Furious on the website? I guess its fitting however considering how many people saw the movie, went out and hooked up a kit and totally fucked their car up.
Old Jun 14, 2002 | 10:30 PM
thanks
I spoke to a Tech at Zex and he gave me this info:
Fuel Jet . . . . . . . Nozzle Jet . . . . . . . Shot
Size . . . . . . . . . . . Size . . . . . . . . . . Size (HP)
36 . . . . . . . . . . . . . 32 . . . . . . . . . . . 55
34 . . . . . . . . . . . . . 35 . . . . . . . . . . . 65
32 . . . . . . . . . . . . . 38 . . . . . . . . . . . 75
Old Jun 15, 2002 | 12:09 AM
KCPreki11's Avatar
Nobody really know the biggest dry shot you can run on a CLS...YET.
Old Jun 15, 2002 | 02:42 AM
edgalang's Avatar
We may not know the biggest possible dry shot...but I wouldnt mind knowing what's the biggest dry shot recorded to date for the TLS/CLS engine.
Old Jun 15, 2002 | 09:20 AM
Sold 12/29/04 :-(
34 . . . . . . . . . . . . . . .35 . . . . . . . . . . . .65
This is the set up I have :P
Old Jun 15, 2002 | 01:46 PM
Doom878's Avatar
Instead of an FPR I'd recommend a VAFC and dyno tune it so that you can have air/fuel properly set. If you're gonna run a higher shot you definitely want to be safe. I don't think I would recommend a 75 shot for this car because of the tranny issues. SFLA knows what I'm talking about. So do some of my other AV6 buddies.
Old Jun 15, 2002 | 02:09 PM
CLSmike's Avatar
TheCarBreathesNitrousToo!
I have a 75 shot 32....38
It runs good.....GREAT....especially when racing some nice V8's
Old Jun 16, 2002 | 08:22 PM
Let me make a small change to the above quote!
I have a 75 shot 32.....38
It runs good.....GREAT....especially when racing some nice CL-S's :P
Old Jun 25, 2002 | 02:11 PM
Paul750's Avatar
to the guys running the 65 and 75 shots. Did you guys retard your ignition and what kind of fuel set up are you running?
Paul
Old Jun 25, 2002 | 02:34 PM
JasonT's Avatar
Do you need to change your plugs? On that NO2 site they said to change the plugs a heat range lower.
Old Jun 25, 2002 | 05:47 PM
Sold 12/29/04 :-(
Paul
The only thing I changed was my spark plugs. Stock timing & stock fuel.
Old Jun 25, 2002 | 07:02 PM
SiGGy's Avatar
Moderator Alumnus
Taken it to the track?
Old Jun 25, 2002 | 08:33 PM
I'm running Zex plugs (2 heat ranges cooler than stock).
I have NOT retarded the timing since I'm running 93 octane (with octane boost at the track).
I will be installing a higher rate fuel pump and regulator within the next 2 weeks.
I suggest installing a tranny cooler to help combat the higher heat generated with running N2O.
Old Jul 3, 2002 | 05:14 PM
Paul750's Avatar
so you guys are saying that i can run the larger shots without retarding the ignition.(65,75) To the zex owners is there a big difference between the 55 and the 65 shot! because my friend had a zex kit on his civic and the increase in shots were not consistant. meaning his 55 shot jets made approx. 35-40 hp @ the wheels and when he swithced to the 65 the hp #'s were about the same no real increase from 55 to 65, then when the 75 jets were installed it added almost 100hp to the wheels! so how consistant is it on our car's
And how much nitrous do you think our car's can take? and do our cars come with forged pistions?
thanks
Paul
jspangan
ILX
Aug 18, 2020 11:05 AM
cycdaniel
Dec 17, 2019 10:58 AM
InFaMouSLink
Oct 27, 2015 06:51 PM
EE4Life
Sep 11, 2015 10:13 PM
nuldabz
Sep 3, 2015 05:49 PM
