J32a2 Nitrous???......
Old Oct 26, 2009 | 10:28 PM
AndresRivera's Avatar
I think there is a cl-p on here thats spraying
how can our engines do on a 50 or below shot?
Recommended?
Old Oct 27, 2009 | 12:19 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
I have a clp and spraying 100shot. I started at 65shot,as soon as the bottle was empty went to 100 but I don't recomend going higher than that without a tune and more fuel.
Old Oct 27, 2009 | 12:56 AM
stlswagger's Avatar
Auto tranny holding up to all that additional power? I'd be scared out of my mind to spray with all those tranny issues stock.
Old Oct 27, 2009 | 04:39 AM
Rajca's Avatar
wham bam thank you ma'am
125 dry spraying, about to spray 50-75 wet direct port. ull be fine. deff anything over 100 u need a tune
Old Oct 27, 2009 | 09:03 AM
fuzzy02CLS's Avatar
I know people who ran 75 dry. I wouldn't go over that to be safe without some sort of tuning.
Old Oct 27, 2009 | 10:10 AM
Trans has never sliped on the spray.
My car trans only ever slipped once.
I was spinning tires and went from dry to wet to dry.bbut thats it.
I think the ecu just did'nt know how to react.
Old Oct 27, 2009 | 01:13 PM
Iwanna Spray
i wanna do a 50 shot of maybe dry or wet
what is recommended to not most likely to fry out my engine!!
Old Oct 27, 2009 | 01:58 PM
Get the zex dry kit it does everything for you.
No need to adjust seprate seilnoids.you put jets in and thats it once it's programed.Also start at the 65 shot.
I sprayed it back to back,light to light till it was gone and no issue's.
The 65shot will probally be about 50hp.
Old Oct 27, 2009 | 02:57 PM
What About the ZEX SAFE SHOT can u send me a link of what u have in your's?
Old Oct 27, 2009 | 03:09 PM
Rajca's Avatar
I was spraying my tl-s with a 100 shot dry, engine fine, trans not so good, went on the dyno, let it rip in 3rd gear and well, that was the end of my 3rd gear. But I've been racing my tl with nitrous for over a year and it was all good.
Old Oct 27, 2009 | 03:34 PM
this is new.
http://cgi.ebay.com/ebaymotors/ZEX-8...Q5fAccessories
Start looking into putting one together. here's one I found real quick.http://cgi.ebay.com/ebaymotors/Zex-D...Q5fAccessories Ask him if it has the nossle and jets.
It looks like it has the long line and the short line atleast.If it dont have nossel and jets you can get both for about 15 bucks or so.Then you will have a kit. fill the bottle and have fun for cheap dough.
Old Oct 27, 2009 | 04:29 PM
Originally Posted by richardparker
this is new.
So u Totally recommend nitrous for my car?
Old Oct 27, 2009 | 04:46 PM
If you are worried keep it at a 75 shot and under.
You will bring a smile to your face from the first time you activate it,"Promise".Also you will be wondering why you did'nt get it sooner.
Old Oct 27, 2009 | 05:06 PM
well idunno i will prolly do my 2jz but idk about a j32a2
Iwant to do it soo bad but dont want to fry engine
ihave a mostly stock engine BTW
Old Oct 27, 2009 | 05:26 PM
I'm not going to twist your arm kid,but you "should'nt" have a problem with a 65shot.
Old Oct 27, 2009 | 05:46 PM
Rajca's Avatar
thats what i told u, lol.
u will be good with a 65 shot all day.
Old Oct 27, 2009 | 06:22 PM
^I think you might of said something simular.
I wont go with it now.
Old Oct 27, 2009 | 07:52 PM
StreetKA's Avatar
how much is it and where can we fill the empty botle up with n2o ?
Old Oct 27, 2009 | 08:01 PM
civicdrivr's Avatar
Most speed shops have N2O tanks.
Old Oct 27, 2009 | 08:15 PM
malvothegreat's Avatar
I have an 01 cls and I have been spraying a 100 shot about 2 months trans fine long as you have a cooler
Old Oct 27, 2009 | 08:44 PM
I don't have a tranny cooler but,it don't sound like a bad idea to have one.
Old Oct 27, 2009 | 08:51 PM
Rajca's Avatar
never had on nor needed one. its the down shifts that make out trannys go, not heat
Old Oct 27, 2009 | 10:12 PM
friesm2000's Avatar
B A N N E D
or try gas supply places (like welding gas supply places)
btw: i do know argon, oxygen and acetiline are welding gases
i know the local gas supply place near me does have N2O, i've dropped off bottles there before for somebody else
Old Oct 27, 2009 | 10:54 PM
jaMezBOI's Avatar
philly flickin'
What is the difference between dry and wet nos? Which is preferred, and what company is preferred?
Old Oct 28, 2009 | 12:00 AM
Wet mixes with the nitrous and fuel when sprayed out of the nozzle. Dry just sprays nitrous out of the nozzle.
Old Oct 28, 2009 | 12:03 AM
And really 75 shot on up you need to run a cooler plug like 1-2 degrees cooler.
Old Oct 28, 2009 | 12:05 AM
TarzanCLS's Avatar
in a nut shell:
1)dry shot is pure N20 from the bottle w/ no additional fuel
2)wet shot runs a second fuel delivery solenoid (most times from the fuel line) to mix w/ the n20 as it goes into the intake
Old Oct 28, 2009 | 12:29 AM
I have 1 step colder zex plugs with the 100shot and it works good
Old Oct 28, 2009 | 01:03 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
50 shot is nothing, u should be fine
Old Oct 28, 2009 | 10:47 PM
jaMezBOI's Avatar
philly flickin'
Originally Posted by TarzanCLS
in a nut shell:
Thanks, is one easier on the engine than the other?
Old Oct 28, 2009 | 11:29 PM
TarzanCLS's Avatar
dry shot is wayyy easier to set up, for the wet you have to tap the fuel line and run a second solenoid. worst car i ever set up was an IS350 (fucking spaceship) but in my experience, wet shot is better performing, and better for the motor.
Old Oct 28, 2009 | 11:39 PM
wet shot is safer in my opinon too.You can always add the needed fuel but,I think its more of a PITA too, always adjusting solenoids every time you change jets.
dry is definitly for the noob nos user.
Old Oct 29, 2009 | 03:21 PM
CLPimpin114's Avatar
Tokin up in
Always had this on my mind! So iHave an 01 CLS stock motor. Will puttin nos in her be a problem? Like most said ill most likey do a 50-65 dry shot. Good???
Old Oct 29, 2009 | 03:25 PM
No problem,I would even bother starting at 50
Old Oct 29, 2009 | 03:40 PM
Cocoa's Avatar
2600lb CL
125 wet shot for about 4-5 yrs? On my 3.0 and on this 3.5
You don't even need a tune. Just colder plugs and high octane gas to help prevent for detonation (i'm running 1 degree cooler, but 116 octane alcohol). Don't use it in overdrive gears either. Don't abuse it. Do that, and you'll be just fine.
Old Oct 29, 2009 | 06:25 PM
Rajca's Avatar
^got balls. ill be right their with u but with direct port.
any engine will be fine with a 50 shot dry. as long as its installed right.
Old Oct 29, 2009 | 09:07 PM
Cocoa's Avatar
2600lb CL
I've been wanting a direct port since I ever started using nitrous. Don't have a clue why I've never done it. It is great as it evely distributes the nitrous in all cylinders compared to the typical case of running it through the intake/throttle body.
Just want to add something for the OP, if you tune it just remember you don't run the car on nitrous 24/7. Therefore you have to get something that would allow you to have 2 fuel maps, 1 on the bottle and 1 off the bottle.
Old Oct 29, 2009 | 09:12 PM
Rajca's Avatar
im putting my foggers in the mdx spacer (i made a thread about it and a diy) great place for it.
Old Oct 29, 2009 | 09:29 PM
friesm2000's Avatar
B A N N E D
that is what i always thought and it be if you could get the engine cover back on, and it basically be direct port (cause it is not spraying directly onto the valves but close enough
