Which Iridium spark plugs to order?
Re: Which Iridium spark plugs to order?
Originally posted by JRock
Anyone know the brand, item number/name, and gap we need?
Thanks.
Thanks.
Originally posted by unsure
why the ik20s and not the ik16s? the ik20s are designed for F/i and/or nitrous, the ik16s are 4 naturally aspirated engines and those are the ones i have on my accord v6
The TYPE-S requires a one step richer plug than the ACCORD or regular CL/TL.
IK20s are in the FAQ, and what is recommended for our cars.
Old timer
Where to order? Does ACP stock them for our car?
It seems like they do
http://www.autocarparts.com/search/r...=Spark%20Plugs
but do they send you the IK16 or IK20? They don't really say which they send you. :-\
edit again - looks like they send you IK20s because that's what are in my cart when I added a set to my cart.
Hmmm $97. Think it's worthwhile yet with 36k on my stock plugs?
sidemarker
Ouch. I know I bought mine locally for $60 bucks.
I bought these awhile ago from ACP, but never had the time to do the install. I'm thinking of getting a new car sometime in '03.......so I'm not going to bother to install these. They are still in the box too.
How come you sellin' them?
Personally i think that people expect too much out of the Denso's. They dont give much power at all, maybe 1-2 whp(nothing noticeable). Main thing is that it will help gas mileage slightly and the idle is a bit smoother.
Personally i do like them and would buy iridium plugs again, just not for the retail price of them. If you can organize 100 plugs to get sold, you can get them at a considerable discount.
If you cant get the 100 plugs sold, i'd probably just go with the NGK iridiums, they are a hell of a lot cheaper.
And btw the CL-S/TL-S does take the IK20.
Full-Time IDIoT---DoH!!!
Originally posted by typeR
acctually denso .com recomends the IK16's for the typeS which i was confused by because i always thought we needed the 20's
Exactly, i was told that by them as well...
Silverbullet, I know u do not have an Accord (just happen 2 have a car heavily based on one ) but when i was researching the densos it came across many times that the ik16s were for Na applications and the ik20s were for nitrous since the ik20s are one stage cooler...also both ik16s and ik20s come pregapped, gapping them urself will result in engine misfire
for the CL/TL i do agree to go with the IK16, but for the Type-S models i'd go with the IK20. Considering that stock NGK plugs are a step colder between the accord and CL-S, i feel the IK20 is the correct plug to use.
Originally posted by oghondaman
Doesn't the #'s refer to the heat range? I always thought low#s as being cold and high#s as being hotter?
Depending on the plug manufacturer (Bosch, NGX, Denso, etc) the heat range numbering can differ...
Newer Bosch plugs (“W” part #) use higher numbers for HOTTER plugs. NGX, and Denso go the other way (higher is COLDER).
I just came from denso's website and it says that the Acura Cl uses Ik16s AND that the plugs are exactly the same as the accord v6s
Try it urself,
link
Try it urself,
link
IK20s are for the TYPE-S
IK16s are for the Accord/CL/TL base forms.
Originally posted by SilverBullet
Uhhhh please leave the site if you keep informing everyone of the wrong info.
uh i went to denso and it said IK16 you want me to leave too...
i believe you but not because it says it in the FAQ on this board...denso doesnt show typeS or not which would lead people to belive its for both...that is probably an error but dont give some one shit when the manufacturer's web page says one thing and we another
He was the one argueing trying to push the fact when he was wrong. I don't want others thinking that is what they are suppose to use. He doesn't own our car.
Bro, I may not own a CL but that doesn't make me incompetent when it somes to my knowledge of Acuras. Granted I may not have as much experience w/cars as you do but I was just interpreting what I came along from the company itself. I also thought the Cl-S need ik20s due to higher compression and spark but Denso's reps said that the ik16s were the appropriate plugs.
I just read Nashua's post and if its pdf'ed from denso, something I didn't come across before, then it must be right. Sorry for the wrong info, it was an honest mistake
xsilverhawkx
09-28-2015 06:51 PM
