Intake manifold thermal gasket
Old May 27, 2018 | 02:07 AM
AcuraMikey's Avatar
Exclamation Intake manifold thermal gasket
so i recently started to experience horsepower loss (alot)... and i thought my piston rings were bad ... i was working on my car earlier today ,took off the intake manifold and notice that my thermal gasket had melted a bit and the egr port on the gasket was not even wih the port on the lower runners .. therfore causing a gasket leak ... wow those things are garbage do not use!! I need to check my t.b because i have one on there aswell..
Old May 27, 2018 | 10:17 PM
AcuraMikey's Avatar
Old May 27, 2018 | 10:21 PM
AcuraMikey's Avatar
Old Jun 1, 2018 | 01:45 PM
90foxnotch's Avatar
Damn, I was about to order one of these for when I do the valve adjustment. Maybe Ill hold off. No fun
Old Jun 1, 2018 | 05:48 PM
cls6life's Avatar
That's crazy, I wonder what caused this.. Has anyone else experienced this issue? How many miles did you put on the car with it installed before failing?
Old Jun 15, 2018 | 06:57 PM
InspireJ32A's Avatar
This seems strange. I've been running a P2R gasket for over a year now, 30000 miles and zero issues. I removed the IM recently - nothing abnormal to report.
Old Jun 16, 2018 | 10:33 AM
Flexing my musCL-S's Avatar
Hmm, car puffs white smoke, IM gasket deforms from heat. Wonder what caused that...
Old Jul 15, 2018 | 11:47 AM
JDM CLS6's Avatar
Hmmm...same. I just installed P2R thermal gasket and the car now idles funny and I get a P0505 code. I bought a new Idle Control Valve and PCV valve and still does the same. I may have to take the manifold apart again to check for leaks since that's the only thing I could think of (maybe the gasket is not on properly).
Old Jul 15, 2018 | 01:50 PM
AcuraMikey's Avatar
YEss i experiences the same idle problem .. thats what happens when you over tighten the intake manifold it squeezes the gasket out of place .. ( besides they dont even give alot
of performance.. i just took mine off i rather not buy anymore of those gaskets
Old Jul 15, 2018 | 05:20 PM
90foxnotch's Avatar
I just put one on my 07 tl and it idled fine. I guess we’ll see after a while if I have any issues. The main idea behind these is not to gain power but to keep the intake cool by not transferring heat. My friend has one on his 06 accord and before you could hardly touch the intake manifold without being burned, now after a 30 minute drive and plenty of hard pulls it’s fairly cool to the touch.
Old Aug 1, 2018 | 12:59 PM
Right, had to take my thermal gasket off...( My motor wouldn't idle properly when cold, plus you could hear much more than you were supposed to (as in valvetrain noise and engine internals doing their thing, caused by a pretty serious leak in the intake). As soon as I installed a regular metal gasket, the engine quieted down. Idle seems to be fine too now.
Nitin
Jul 28, 2014 10:35 PM
boosted2000si
Jul 23, 2012 02:59 PM
deadlyklappy12887
Apr 26, 2010 07:26 PM
Kramer1
Dec 2, 2009 05:56 PM
ianfromdaygo
Feb 24, 2007 11:46 PM
