Installing the Aluminum Climate Control knobs
Old Jul 15, 2004 | 10:32 PM
Dem1K's Avatar
Got a Job!
How the hell do you do it? I just bought the accent rings, radio & climate control knobs from fuzzy02cls, and I got the radio knobs on fine, as they just slide right in, but the climate control knobs are the tricky part. When you pull off the stock knobs, the shaft is shaped in a semi-circle, whereas the new knobs have a shaft shaped in a complete circle. So when I put them on the shaft, they just slide around and dont fit snug at all.....basically, they will fall off EXTREMELY easy. How the hell do you put these things on? Any help would be great
Old Jul 16, 2004 | 12:31 AM
NiteQwill's Avatar
Adventurist.
Use some felt cloth to plug the hole up to make it tighter.
Old Jul 16, 2004 | 12:53 AM
Red-CL's Avatar
Doin' da crack shuffle
I just used some paper towels to make the hole tighter.
Old Jul 16, 2004 | 01:11 AM
Dem1K's Avatar
Got a Job!
well I don't have any felt cloth, so skip that idea...thanks though
as for paper towels, did you just tear a few small pieces and shoved them in there?? I don't get it, lol
Old Jul 16, 2004 | 08:21 AM
fuzzy02CLS's Avatar
I pm'ed you. The instructions I gave you are the instructions I got that came with them. From what I can remember anyway.
Old Jul 16, 2004 | 08:26 AM
Red-CL's Avatar
Actually, I cut a toothpick the length of the shaft with the flat part and wrapped small pieces of paper towel around the tooth pick. I then lined it up and slid the knob on. Make sure the toothpick is on the flat part of the shaft.
Shaft = aluminum part that the knob slides on and off
Hope this helps.
Old Jul 16, 2004 | 10:03 AM
niz181's Avatar
i just pulled the stock knobs off and lined up the new ones and pushed them on and they fit perfect
Old Jul 16, 2004 | 12:52 PM
Smitty's Avatar
What?... all you have to do is take a very small screw driver and slide the RING out of the STOCK knobs...
i just did it last week.. everything works perfectly...
Old Jul 16, 2004 | 08:02 PM
Dem1K's Avatar
Got a Job!
aight I got it to work...I found a very tiny screwdriver and used it to pry out those little metal inserts and it worked great. I'll post pics in a bit
Thanks for all of your guys help! Rep points indeed
Old Jul 16, 2004 | 09:34 PM
Red-CL's Avatar
I never even thoguth of that.
Old Jul 16, 2004 | 09:57 PM
Dem1K's Avatar
Got a Job!
heres pics..
http://f1.pg.photos.yahoo.com/ph/dem...ahoo.com/dem1k
Old Jul 16, 2004 | 10:03 PM
UNCTYPE-S's Avatar
Above n Beyond
where did u find those from?
Old Jul 16, 2004 | 10:07 PM
Dem1K's Avatar
Got a Job!
well, some guy on the a-tl forums made some, and I bought them off somebody on these forums... Here's the link to the a-tl thread:
http://www.acura-tl.com/forums/showt...ht=radio+knobs
and also on acurainspired.com
http://www.acurainspired.com/forums/...showtopic=3599
Old Jul 16, 2004 | 10:22 PM
Red-CL's Avatar
Originally Posted by Dem1K
That look exactly like my car.
Old Jul 16, 2004 | 10:32 PM
Dem1K's Avatar
Got a Job!
Old Dec 6, 2004 | 09:17 PM
VeeralS05's Avatar
I NEED MONEY!
I just got mine, stick your key in the hold of the original than pull out the metal bracket its the shape of the fitting for the knob and than just slide that bracket into the hole of the new knob and tada! I didnt know wht to do till i looked in the hold of the original and i saw this thing i was like wtf is this than i stuck my key in it and pulled it out and i was liek wow! and i stuffed it into the new one and it works jst like the original one!
Feb 25, 2020 09:57 AM
lovic87
Sep 15, 2015 06:07 PM
PortlandRL
Sep 14, 2015 12:01 PM
EE4Life
Sep 11, 2015 10:13 PM
HOWELLiNC
Sep 5, 2015 03:09 AM
