Installing the Aluminum Climate Control knobs
Got a Job!
How the hell do you do it? I just bought the accent rings, radio & climate control knobs from fuzzy02cls, and I got the radio knobs on fine, as they just slide right in, but the climate control knobs are the tricky part. When you pull off the stock knobs, the shaft is shaped in a semi-circle, whereas the new knobs have a shaft shaped in a complete circle. So when I put them on the shaft, they just slide around and dont fit snug at all.....basically, they will fall off EXTREMELY easy. How the hell do you put these things on? Any help would be great
Got a Job!
well I don't have any felt cloth, so skip that idea...thanks though
as for paper towels, did you just tear a few small pieces and shoved them in there?? I don't get it, lol
Doin' da crack shuffle
Actually, I cut a toothpick the length of the shaft with the flat part and wrapped small pieces of paper towel around the tooth pick. I then lined it up and slid the knob on. Make sure the toothpick is on the flat part of the shaft.
Shaft = aluminum part that the knob slides on and off
Hope this helps.
Hope this helps.
What?... all you have to do is take a very small screw driver and slide the RING out of the STOCK knobs...
i just did it last week.. everything works perfectly...
Got a Job!
aight I got it to work...I found a very tiny screwdriver and used it to pry out those little metal inserts and it worked great. I'll post pics in a bit
Thanks for all of your guys help! Rep points indeed
I never even thoguth of that.
Got a Job!
well, some guy on the a-tl forums made some, and I bought them off somebody on these forums... Here's the link to the a-tl thread:
http://www.acura-tl.com/forums/showt...ht=radio+knobs
and also on acurainspired.com
http://www.acurainspired.com/forums/...showtopic=3599
Originally Posted by Dem1K
I NEED MONEY!
I just got mine, stick your key in the hold of the original than pull out the metal bracket its the shape of the fitting for the knob and than just slide that bracket into the hole of the new knob and tada! I didnt know wht to do till i looked in the hold of the original and i saw this thing i was like wtf is this than i stuck my key in it and pulled it out and i was liek wow! and i stuffed it into the new one and it works jst like the original one!
