IMRC Needs to be Disconnected???
Old Jul 17, 2005 | 04:16 PM
CL FWD SPEED's Avatar
What to do, what to think
Question IMRC Needs to be Disconnected???
I'm planning on installing the Supercharger soon...I've heard someone on this forum said that you will Need to Disconnect the IMRC when the supercharger is installed. Why is that? what will happen if the IMRC is connected? the Symptoms? I thought the IMRC activates the VTEC and increases our HP...call me stupid but I"m a little confused here.....
Old Jul 17, 2005 | 05:19 PM
babyblue's Avatar
Sold but not Forgotten...
if you have it connected most ppl have noticed pinging... Most members have it disconnected
Old Jul 17, 2005 | 06:14 PM
mrsteve's Avatar
IMRC has nothing to do with VTEC! Disconnect it.
Old Jul 17, 2005 | 09:30 PM
Smitty's Avatar
It is a Simple Butterfly valve that opens up to let air flow dump directly into the runners instead of bouncing around in the intake manifold then going into the runners..
Disconnecting it leaves the butterfly valve closed since you are forcing air into the intake manifold via Supercharger.
Old Jul 17, 2005 | 11:20 PM
ahhhhhh I get the picture now....I'm starting to mod the ride now since I've paid the car off. Its been stock for 3 years now hopefully things will improve within the performance
Old Jul 17, 2005 | 11:29 PM
shit!! My stupid ass friend once told me that it engauges the VTEC....I"m such a moron for believeing his ridiculous intellect :troutslap
I'm so glad there is the acurazine site for FAQ
thanks guys
Old Jul 17, 2005 | 11:48 PM
mrsteve's Avatar
Take the top plate of the intake manifold off and you'll see the butterfly. It goes from "_" to "|" when the actuator engages.
Old Jul 19, 2005 | 01:00 AM
Allout's Avatar
Blown is Best
If you're running standard boost pulley, you do not need to disconnect IMRC. If you're running high boost pulley and have marginal fuel, disconnecting IMRC helps with pinging problems at VTEC changover. Keep IMRC connected if you can do so without issues.
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Rapture
Oct 4, 2015 12:05 AM
cali boy 91
Sep 19, 2015 01:57 PM
scionxb3003
Sep 14, 2015 01:52 AM
