Ignition wire info...need help
Old Dec 13, 2006 | 07:19 PM
BigLizard's Avatar
Moderator Alumnus
Thumbs up Ignition wire info...need help
I need to know what color the power wire for the ignition looks like and where it's located.
If anybody can take a picture of the location of this and what it looks like that would be great. I have a small project I'm doing on the side.
Thanks in advance for the help!
Old Dec 13, 2006 | 09:23 PM
CleanCL's Avatar
im pretty sure its the nice fat white wire behind the fuse panel, it might be red though. one of those 2 colors.
Old Dec 13, 2006 | 09:50 PM
BigLizard's Avatar
Moderator Alumnus
I noticed that there is a plug behind the fuse box with a big fat white wire, it is definately bigger than all the other wires...I also saw another big white wire with black markings (I am assuming this is the ground wire).
Old Dec 13, 2006 | 10:11 PM
CleanCL's Avatar
yup its probly that, it kind of leads under the steering column, thick white wire.
Old Dec 13, 2006 | 10:14 PM
BigLizard's Avatar
Moderator Alumnus
Coolness...I will check this out tomorrow morning when I'm not all doped up.
I took a morhine pill earlier for my back and I feel nooooooooooooooooo pain. (Back issues from my accident still .)
Old Jan 6, 2007 | 09:27 PM
bhurlbut's Avatar
ignition wire
wuddup greenmachine, so is it the fat white wire?
Old Jan 7, 2007 | 04:29 AM
BigLizard's Avatar
Moderator Alumnus
Old Jan 7, 2007 | 11:09 AM
Louie11's Avatar
If you are just looking for an easy ignition and 12v source. Our cars by the driver kick panel fuse box has 3 open jumpers on the lower left. 1 is ign. and the other 12v. This way you don't have to splice into any wires. You just need a solderless female connection and plug it in.
Old Jan 7, 2007 | 11:46 AM
ThinJim's Avatar
without checking and going by memory, on mine i beleive it was the big fat yellow wire with a black strip. that is wire that provides constant voltage while starting the motor.
wad a ya doin?
Acura604
20
Aug 5, 2017 12:55 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
malvothegreat
Sep 29, 2015 12:38 AM
