icebox problem
icebox problem
i tried to remove the cover to get to the filter and one of the bolts just spins. i guess the threaded nut in the lower section of the box is turning.
has anyone else had this problem? how did you fix it?
thanks
thanks
I did the same. Actually, two of mine came out, one was stuck. I was able to stick a screw driver under the lid and pop it off (taking the screw out with it. But I have a self tapping screw in there now.
i just pulled the cover off...upwards. the bottom nuts will come out with the screws. as mentioned abve, if you can get an angle, use a screw driver then pry it open.
Doin' da crack shuffle
Happened to me recently too.
I still have yet to fix it. Not time for a filter change yet.
I honestly didn't feel like dealing with it now cause mine is the front screw that keeps spinning.
Maybe in the Spring.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Maybe in the Spring.![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Originally Posted by icy CL
yup. that's the first thing that happened to me. pulled the cover up and it came off. next, the two rear screws when i had my car serviced by acura. had to pull those two off. now when ever i check my filter, i just don't tighten the screws too much.
I'll have to take my battery out to get beside it and pry it open. I thought about that but didn't wanna damage my icebox doing so. I'll try it when the weather clears up.
thanks guys.
i thought the icebox would free me from cai problems.
Originally Posted by NiteQwill
Did they fix the problem? Like have metal threads with metal around it too.....
And I thought this wasn't anything new? I've heard of a few people talk about that who have the Icebox.
Originally Posted by fuzzy02CLS
Happend to me also. I broke the bolt. Comptech sent me a new box under warranty though I did have to pay for shipping the old one back.
i probably tightened it too much
Yup, I had this problem with my Icebox too. I basically had to rip the lid off, and the one screw that was stuck ripped out with the thread nut still around it. I took the thread nut off, pressed it back into the hole, and put in a new screw that was a little bit larger.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
