icebox problem
Old Oct 19, 2004 | 03:34 AM
mattg's Avatar
icebox problem
i tried to remove the cover to get to the filter and one of the bolts just spins. i guess the threaded nut in the lower section of the box is turning.
has anyone else had this problem? how did you fix it?
thanks
Old Oct 19, 2004 | 06:18 AM
scalbert's Avatar
I drilled out the head and then pulled the insert. When reinstalled I used a self tapping screw.
Old Oct 19, 2004 | 08:31 AM
mrsteve's Avatar
I did the same. Actually, two of mine came out, one was stuck. I was able to stick a screw driver under the lid and pop it off (taking the screw out with it. But I have a self tapping screw in there now.
Old Oct 19, 2004 | 08:33 AM
icy CL's Avatar
i just pulled the cover off...upwards. the bottom nuts will come out with the screws. as mentioned abve, if you can get an angle, use a screw driver then pry it open.
Old Oct 19, 2004 | 11:15 AM
fuzzy02CLS's Avatar
Happend to me also. I broke the bolt. Comptech sent me a new box under warranty though I did have to pay for shipping the old one back.
Old Oct 19, 2004 | 12:01 PM
Red-CL's Avatar
Doin' da crack shuffle
Happened to me recently too.
I still have yet to fix it. Not time for a filter change yet.
I honestly didn't feel like dealing with it now cause mine is the front screw that keeps spinning.
Maybe in the Spring.
Old Oct 19, 2004 | 12:05 PM
icy CL's Avatar
yup. that's the first thing that happened to me. pulled the cover up and it came off. next, the two rear screws when i had my car serviced by acura. had to pull those two off. now when ever i check my filter, i just don't tighten the screws too much.
Old Oct 19, 2004 | 01:06 PM
Red-CL's Avatar
I'll have to take my battery out to get beside it and pry it open. I thought about that but didn't wanna damage my icebox doing so. I'll try it when the weather clears up.
Old Oct 19, 2004 | 01:31 PM
mattg's Avatar
thanks guys.
i thought the icebox would free me from cai problems.
Old Oct 19, 2004 | 01:40 PM
NiteQwill's Avatar
Adventurist.
Did they fix the problem? Like have metal threads with metal around it too.....
Old Oct 19, 2004 | 02:04 PM
mclarenf3387's Avatar
I believe they did.
And I thought this wasn't anything new? I've heard of a few people talk about that who have the Icebox.
Old Oct 19, 2004 | 02:12 PM
R1Performance's Avatar
Power of Dreams
I had the same experience with my icebox in my RSX. Comptech sent me a replacement via air shipping to VA asap. They did send a return packing slip for the faulty unit too. Seems they are aware of the problem with this product across the model range, thus far though, I think their solution is to stress not over tightening the bolts.
Old Oct 19, 2004 | 03:55 PM
mattg's Avatar
i probably tightened it too much
Old Oct 19, 2004 | 04:32 PM
Red-CL's Avatar
Yeah, I get a bit heavy handed sometimes too
Old Oct 19, 2004 | 04:45 PM
Smitty's Avatar
another quality part that we all paid alot of money for.. oh well.
Old Oct 19, 2004 | 05:10 PM
Shadzilla's Avatar
Yup, I had this problem with my Icebox too. I basically had to rip the lid off, and the one screw that was stuck ripped out with the thread nut still around it. I took the thread nut off, pressed it back into the hole, and put in a new screw that was a little bit larger.
Old Oct 19, 2004 | 05:52 PM
darrinb's Avatar
///M POWER
thats comptech for ya
Old Oct 19, 2004 | 06:18 PM
psd112's Avatar
So has this problem been fixed? or is another one of those " it is what it is" problems?
Old Oct 19, 2004 | 07:40 PM
NucleusTL2's Avatar
5th Gear
Happened to me to. Drilled out old screws and put bolts and nuts on two corners. Easy fix
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
