How long does it take to put pulleys in?
Old Jul 5, 2001 | 09:47 PM
JarodL's Avatar
Thanks,
Jarod
Old Jul 6, 2001 | 10:46 AM
scalbert's Avatar
It took me about 1 - 1.5 Hrs total but I attempted to swap out the Alternator pulley while it was still on the vehicle.
The Power Steering pulley is a snap and shouldn't take more than about 20 minutes start to finish.
The Alternator is another story. It would be much easier to plan on just pulling the Alternator from the beginning. With that in mind, you can remove it in 15 minutes, swap out the pulleys in another 15 minutes and reinstall in 15 more for about 15 minutes total.
So in all about an hour would be required.
Old Jul 6, 2001 | 11:31 AM
TypeSKid's Avatar
Can you tell a big difference with the pulleys? I'm considering getting them next week, and installing on the 21st.
Old Jul 6, 2001 | 11:37 AM
spiroh's Avatar
scalbert,
Do you have pics on removing the alternator? I would like to try this on my own.
Thanks,
Spiro
Originally posted by scalbert:
<STRONG>It took me about 1 - 1.5 Hrs total but I attempted to swap out the Alternator pulley while it was still on the vehicle.
So in all about an hour would be required.</STRONG>
Old Jul 6, 2001 | 12:08 PM
NOLACLS's Avatar
Yeah if anyone has pictures please put them on here. I would like to try to do the pulleys but I don't want to run into any problems with my stereo system...and if I do I would like to be able to pull them off myself and not PAY any more $ than I have to. Any directions, tools needed, or any help would be awesome. Thanks guys.
Old Jul 6, 2001 | 12:15 PM
spiroh's Avatar
I'm also working on a project other then installing the aem pulleys. I'm going to see if I can get the crank pulley lightened, by making it aluminum. The size will be the same, just the pulley would be lighter.
Spiro
Old Jul 6, 2001 | 01:00 PM
tankmonkey's Avatar
6 speed...
Originally posted by spiroh:
<STRONG>I'm also working on a project other then installing the aem pulleys. I'm going to see if I can get the crank pulley lightened, by making it aluminum. The size will be the same, just the pulley would be lighter.
Spiro</STRONG>
does the crank pulley incorporate a(n) harmonic balancer?
if so, I would think lightening it would be a bad thing with respect to engine vibration.
Old Jul 6, 2001 | 01:20 PM
spiroh's Avatar
I have no clue. I'm looking in to it.
Spiro
Originally posted by tankmonkey:
<STRONG>
if so, I would think lightening it would be a bad thing with respect to engine vibration.</STRONG>
Old Jul 6, 2001 | 01:35 PM
scalbert's Avatar
<STRONG>
</STRONG>
Unfortunately I didn't take any pics of the install. However the Helms manual does go over it.
It is actually an easy process and can be done from the top. Just carefull bend the AC compressor line to the side and the Alternator will come up through the 'hole'.
Old Jul 6, 2001 | 01:41 PM
scalbert's Avatar
Originally posted by TypeSKid:
[QB]Can you tell a big difference with the pulleys? [QB]
Not a huge difference or really any at all. Nor did I expect one, maybe a little better throttle response but that is it. To really feel a difference you need atleast a 5% gain, but more like 10%.
The pulley on the other hand only give a few HP but it does increase the power throughout the antire band. So a few lb/ft all over the rev band will decrease you times.
Old Jul 6, 2001 | 01:50 PM
NOLACLS's Avatar
Can someone post the helms pages on removing the alternator?
Old Jul 6, 2001 | 02:15 PM
spiroh's Avatar
Nola,
You are on top of shit
Spiro
Originally posted by NOLACLS:
<STRONG>Can someone post the helms pages on removing the alternator? </STRONG>
Old Jul 6, 2001 | 02:27 PM
NOLACLS's Avatar
Spiro,
Thanks, do you think it made a difference with the pulleys. Has it effected your stereo stuff. I have the 300/4 and I plan on running a 250/1 on a 10w3. Do you think I will have to worry about stalling or anything crazy like that with the pulleys??
Old Jul 6, 2001 | 02:32 PM
spiroh's Avatar
I have not installed the pulleys yet. I have close to 1600watts so I hope there wont be a problem =) I wouldnt worry about it too much.
Spiro
<STRONG>Spiro,
Thanks, do you think it made a difference with the pulleys. Has it effected your stereo stuff. I have the 300/4 and I plan on running a 250/1 on a 10w3. Do you think I will have to worry about stalling or anything crazy like that with the pulleys??</STRONG>
Old Jul 6, 2001 | 02:34 PM
NOLACLS's Avatar
Spiro,
are you going to try to install them yourself? 1600w DAM does it make all your lights dim when it hits or do you have a cap or something like that?
Old Jul 6, 2001 | 02:53 PM
spiroh's Avatar
I have a cap. My JBL 1200.1 is class D which makes it efficient. Even without the cap my lights dont dim. I have also added another amp for my interior speakers, which I will be connected the cap to.
Spiro
<STRONG>Spiro,
are you going to try to install them yourself? 1600w DAM does it make all your lights dim when it hits or do you have a cap or something like that?</STRONG>
Old Jul 6, 2001 | 03:05 PM
NOLACLS's Avatar
I think the JL 250/1 is a class D so i will see how the light thing goes befor i do a cap. Do you think i can run 1 4 gage wire and split it into 2 4 gage wires for the 2 amps?? And are you planning to do the pullies yourself??
Old Jul 6, 2001 | 03:12 PM
spiroh's Avatar
Yes. I use one 4 guage going to a power splitter to connect both amps with an 8 guage. Yes I want to do the pulleys on my own. Hopefully somebody will post the schematics to the alternator.
Spiro
<STRONG>I think the JL 250/1 is a class D so i will see how the light thing goes befor i do a cap. Do you think i can run 1 4 gage wire and split it into 2 4 gage wires for the 2 amps?? And are you planning to do the pullies yourself??</STRONG>
Old Jul 6, 2001 | 03:46 PM
NOLACLS's Avatar
Well thanks and good luck with the pulleys. Let me know how it goes and what tools you had to use and if i see a post of the helms ill let you know. Hopefuly someone will be real nice and post it
Old Jul 6, 2001 | 03:47 PM
scalbert's Avatar
My manual is at home, but the removal is easy. Just a standard alternator swap. 3 bolts and a little manuevering and it is out. However, the lower back bolt is a tight fit but simple enough.
If someone doesn't beat me to it I'll bring my manual in Monday and make a scan.
Old Jul 6, 2001 | 03:53 PM
NOLACLS's Avatar
Scalbert,
Thanks..just post it whenever you get a chance.
Old Jul 6, 2001 | 04:06 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
In regards to the crank....all Hondas have harmonic balancers...that's why they don't include pulleys for the crank.
Old Jul 6, 2001 | 04:33 PM
spiroh's Avatar
Actually by looking at the crank, I dont think it has a harmonic balancer.
Spiro
Originally posted by moomaster_99:
<STRONG>In regards to the crank....all Hondas have harmonic balancers...that's why they don't include pulleys for the crank.</STRONG>
Old Jul 6, 2001 | 06:31 PM
vuduvida's Avatar
<STRONG>If someone doesn't beat me to it I'll bring my manual in Monday and make a scan.</STRONG>
I just happened to have the manual and scanner sitting right here. I don't even know if linking to pics posted on PhotoPoint work anymore so I'll just post the direct link:
http://albums.photopoint.com/j/Album...5410&f=0&vt=vp
cycdaniel
Dec 17, 2019 10:58 AM
BoricuaTL
Apr 8, 2016 01:08 PM
pozebly
Sep 23, 2015 07:30 AM
iCrap
Sep 11, 2015 06:21 PM
darksky
Sep 5, 2015 03:11 AM
