How long do HID headlights last before you need to replace them?
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
The reason I am asking is because I replaced mine once all-ready and now my passenger light is starting to go. IT flickers and turns on sometimes, sometimes it does not turn on but if i play with the lights(shuting them off and then turning them on) the light will work.
Is it my bulb going or is the alternator that powers the light starting to go?
Thanks for the INFO!
B A N N E D
It seem like when i hit a bump on the road the lights will flicker and shut off.
These are my 2nd set of lights and ballast's so do you guys think it is a bad connection, bad ballast or bad bulb?
B A N N E D
No both where changed b4.. I really dont feel like pumping any more loot into this money pit! The way the economy is going i cant afford a new car or fix my old car!
My right side ballast went out at 78k and I had it replaced and while at it, put in a new bulb. Just a couple of weeks ago the left side ballast went out at 88k. Someone had posted an Acura Service bulletin link dated October 2008 about ballast problems and that helped save me about $225. Anyhow, seems like it must be a broader problem if they put out this bulletin. Hopefully, they'll last a lot longer than the first ones.....
darksky
Sep 5, 2015 03:11 AM
