how long are denso plugs supposed to last?
Re: how long are denso plugs supposed to last?
Originally posted by I am RobG
I already need to change my plugs and i have like 25k miles on the denso iridiums....anyone know anything about them?
After 27K on mine, they had to be replaced. The engine was misfiring and jumping
I had no idea it was the fact the the iridiums were dead. I didn't look as close either when I bought. I now change them every 25K in case, I don't want to get stuck again. Silly though when you think what we pay for these things and they last only less than a 1/3 of the miles of our stock platinum. Sometimes modding isn't logical
I got mine ( NGK iridium ) from www.sparkplugs.com. They are $50 shipped. I have them for some 16kmiles. if they last 30kmiles this is not too good. But I can live with that. I felt difference when they were new. They performed well on the srtrip. Best 1/4 times were with CAI and new spark plugs.
You people have too damn much money to spend! Stock plugs at 45,000 miles and idle is still smooth and car gets to redline as fast as when it was new. No turbo? No SC? Stock plugs are all that are needed. Any other plugs are just; http://storefinder.unclebens.com/mas...top_banner.gif
Dan
Dan
Dan
Dan
Originally posted by t-rd
The stock plugs are platinum, designed for longevity, not performance. These guys by Denso Iridium performance. Isn't that what you are here for? Performance? The Denso Iridiums are dyno proven to show gains. 3lb/ft and 4HP gain on Accord V6. It must be more for CL-S.
Dan
Denso Plugs
Your right, Denso Iridium plugs ARE performance plugs, but if you're running the plug rated for your car you should get plenty of life out of them. I've got 95K miles on mine. A number of things could cause early plug burn-out. If your running a plug too cold for your car, you'll build up carbon fast! If you run too hot of a plug you'll burn the tip in a short amount of time. If you're boosting, run a colder plug and shorten the gap, but you're STILL going to eat plugs. There's no way out. The Iridium plugs have the lowest misfire-rate of any plug. The higher heat transfer capacity reduces "hot spots" that cause pre-ignition power loss.
After all that, it still comes down to what works for you....
Check out
www.FastNDelirious.com/denso
Check out
I put in Bosche Platinum 4's at 11,000 miles and noticed a huge difference, sorta like putting octane booster in yer gas tank. A set of new plugs always makes the car feel faster for a little while, until it starts to carbon track. I put the old plugs into my mom's beater car.
Dan
cycdaniel
Dec 17, 2019 10:58 AM
darksky
Sep 5, 2015 03:11 AM
, why can't we get 93 octane?
