How do I get my car on jack stands?
Old Aug 3, 2008 | 08:42 PM
smokendsm's Avatar
ridin slow'n'low
Is there a better way to get the rear up on stands other than to jack it up using the rear tow hook jackpoint? If I can use the subframe to jack it up... which point to use?
Old Aug 3, 2008 | 09:07 PM
02CL-TypeS's Avatar
I tried the tow hook and it started to dent in.
So now, the only option that I have come up with was to jack the car from the scissor jack points. Only use half the head of the floor to leave enough room for a jack stand. Anyone can do it cause I use a big ass 3-ton floor jack and 3-ton jack stands
Old Aug 4, 2008 | 03:03 PM
NSXNEXT's Avatar
I've always used the rear tow hook and have never had problems.
Old Aug 4, 2008 | 03:04 PM
cb717cls's Avatar
03 Boosted CLS
same
Old Aug 5, 2008 | 03:16 PM
gurot1's Avatar
smokendsm did you use the actual tow hook or the spot immediately behind it? The spot right behind the tow hook looks like it would be the spot to jack it up on (which is what I did when installing my sway bars years ago and bent my trunk bottom a bit, which ended up been good by keeping my sub from moving around the trunk!) but it's not the correct spot.
Old Aug 5, 2008 | 03:24 PM
gurot1's Avatar
my question should have been directed at 02CL-TypeS
Old Aug 5, 2008 | 03:57 PM
02CL-TypeS's Avatar
I used the actuall tow hook. I didn't even get the wheels off the ground if I remember correctly. I remember I saw it start to dent in...barely...so I just stopped jacking it fromt there and did one side at a time
Old Aug 5, 2008 | 06:46 PM
smokendsm's Avatar
ridin slow'n'low
Ive been usin the tow hook and its held up fine but I used a block of wood on top of my jack to get the extra lift thats necessary to put the stands under rear jack points... and my front bumper is almost on the ground.
Old Aug 6, 2008 | 09:25 PM
knight rider's Avatar
Rooting for Acura
leave it in the hood with some 20's on it overnight
Old Aug 6, 2008 | 11:51 PM
swoleCL's Avatar
¿baCon?
lol gurot, i did the same exact thing, even with the SUB LOL!
Old Aug 7, 2008 | 09:12 AM
gurot1's Avatar
We had been putting in my rear sways when it happened. On the drive home I heard this rattling noise in the trunk. At first I thought it was the sways. But when I looked in the trunk I noticed that the spare tire wasn't sitting in the trunk corretly because the trunk had been dented in a little bit! It was great for the sub though, it didn't move much. Now that the trunk bottom has been hammered to the correct level, my sub moves around a lot!
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
