HLSD how do you know it is working?
Old Oct 2, 2003 | 09:48 AM
runnerX's Avatar
Just curious... how do you know if your HLSD is malfunctioning?
Old Oct 2, 2003 | 09:59 AM
Zapata's Avatar
Cost Drivers!!!!
when? straight line? turning?
Old Oct 2, 2003 | 10:03 AM
runnerX's Avatar
turngin or straight line.. does not matter, but I think it does not kick in when traveling straight.
I only felt it once in a rain... I am wondering if my HLSD is not functioning anymore..
Old Oct 2, 2003 | 10:05 AM
fuzzy02CLS's Avatar
I can't even tell when it does kick in. Or if it ever has?
Old Oct 2, 2003 | 10:08 AM
CLS2001_97124's Avatar
Revving at 9K...
jack you car up and spin the front tires. If both wheel spin in the same direction, then it's working.
Old Oct 2, 2003 | 10:10 AM
runnerX's Avatar
hm.... really? I thought the front tires are independent to each other...
Old Oct 2, 2003 | 10:13 AM
Zapata's Avatar
Cost Drivers!!!!
only functions when one wheel looses grip. If you are turning and your car doesn't plow, understeer, etc., HLSD is working It works in straightline accel.....it can actually slow you down.
Old Oct 2, 2003 | 10:29 AM
Slimey's Avatar
Where is my super sauce?
I never thought of it as something that 'kicks in'. It's there and it works like Zapata said.
The only time I really noticed it was last winter when I was backing out my driveway and the right hand wheel was on some slick ice - I felt it slip and then almost instantaneously the car gripped and continued it's trip down the driveway (actually pretty straight, too).
Old Oct 2, 2003 | 11:05 AM
runnerX's Avatar
thx guys... I will just put some soap/oil on one side of my driveway to test it out.. I hope my wife does not mind...
Old Oct 2, 2003 | 11:15 AM
Wires's Avatar
Re: HLSD how do you know it is working?
I can feel mine when accelerating hard and changing lanes fast.
The HLSD causes the front end to pull in the direction I was turning. Sometimes that's cool, othertimes, it's a little freaky since it yanks the front end around.
Old Oct 2, 2003 | 11:25 AM
scalbert's Avatar
It is working otherwise you would probably be hearing it as it is a purely mechanical device.
But to get a feel for it try being in 1st take a corner and get on it. You will feel a shift in the handling where car starts turning in for you; you might also feel the wheel jerk a little.
No, this is not torque steer as it occurs in both directions towards the inside of the direction turning.
Old Oct 2, 2003 | 12:21 PM
joedokes28's Avatar
Pop the clutch at 3500rpm and it if doesn't leave TWO black strips of rubber, it's broke.
Old Oct 2, 2003 | 01:12 PM
scalbert's Avatar
Re: Re: HLSD how do you know it is working?
Be sure to have some new CV joints and whatever else is needed to fix the drivetrain after the horrendous wheel hop you receive. :P
Old Oct 2, 2003 | 01:30 PM
Revving at 9K...
That's what LSD do.. it spins both wheels at the same time rather than just one and then the other.
Old Oct 2, 2003 | 01:49 PM
typeR's Avatar
but the mechanics of the helical gear limited slip allows for variing degrees of torque transfer to one wheel or the other via a sun gear....but like scalbert said it is a mechanical device and id say you'd hear some bad noises as well as have some very bad drivability if it were malfunctioning
Old Oct 3, 2003 | 09:32 AM
Stock03CLS's Avatar
Last winter, I put the right tire in the packed snow and the left tire on the plowed and dry pavement, then goosed the throttle. Car the car kept going straight. Little if any pulling.
HLSD works!
Old Oct 3, 2003 | 02:12 PM
joedokes28's Avatar
Re: Re: Re: HLSD how do you know it is working?
There's no chance of breaking anything if he's sittin on the Michelins they just start spinin and smokin.
Old Oct 3, 2003 | 06:19 PM
joeandcarol2's Avatar
CL 6 speeder
If you are in a turn and understeering a bit. Give it some gas the HLSD bring the front end around like a transistion to oversteer.
mada51589
Jan 9, 2025 04:40 PM
spidermankb
Mar 5, 2019 11:34 AM
acurajj
Sep 19, 2015 03:47 PM
Luis J. Rodriguez
Sep 12, 2015 10:00 PM
ahsm
Sep 9, 2015 08:35 AM
