HELP!!! rotor screw is f'd!
Old Oct 8, 2007 | 11:22 AM
simean's Avatar
Exclamation HELP!!! rotor screw is f'd!
My impact screwdriver bit broke into the rotor screw!!!
I purchased some rotoras from Excelerate and I tried to install them this weekend. I used my impact screwdriver to remove the 2 screws holding the rotors. The screw was on there so tight, that it broke the impact screwdriver bit...INSIDE the screw head.
WTF do i do!?! I tried to drill out the screw...but the hardened bit (that's jammed inside the screw head) is preventing my drill from really being able to work...
Old Oct 8, 2007 | 12:00 PM
PMGCamaro's Avatar
You could use a rotary cut-off wheel to cut a notch into the head of the screw. Then just use the flat head bit with you impact screwdriver to remove the screw
Old Oct 8, 2007 | 12:44 PM
CleanCL's Avatar
drill it out using a reverse threading bit.
err... i forget the exact name, but the bit drills in forwards, then when you reverse it out, instead of just coming it out, it threads itself and turns the screw left.
Old Oct 8, 2007 | 04:07 PM
o1s's Avatar
o1s
i would recomend this as well.
Old Oct 8, 2007 | 04:30 PM
2CLean's Avatar
Well...it's kinda fast...
I agree with CleanCL, a screw extraction bit is your best bet. They sell 'em at Sears and most hardware stores...they saved me lots of time and effort. Once removed there's no need to replace it. It doesn't really serve a purpose other than holding the rotor in place when installing new ones.
Old Oct 8, 2007 | 05:38 PM
PMGCamaro's Avatar
Yes, all those screws do is hold the rotors in place while the vehicle is coming down the assembly line. Once you get them out just toss 'em in the trash.
Old Oct 8, 2007 | 08:07 PM
CleanCL's Avatar
ahh, that's right... extractor bit
Old Oct 8, 2007 | 10:23 PM
Allout's Avatar
Blown is Best
I used a center punch and hammer to drive the screw counterclockwise. I was able to loosen and remove the screw using this method.
Old Oct 9, 2007 | 09:57 AM
fsttyms1's Avatar
taking a ball peen hammer and placing it on the screw(rounded end), then hitting it with another hammer first will make them come out much easier.
Old Oct 9, 2007 | 11:16 AM
artbran's Avatar
666 Speed
That or a chisel.. Thats what I did..
Old Oct 9, 2007 | 01:56 PM
kyle77777's Avatar
Gonna cost to catch up
x2
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
