Help: Headlight Bulb Replacement
Old Oct 28, 2007 | 09:04 PM
zshan1979's Avatar
5th Gear
Hi CL gurus..
I recently got an Acura CL 2001 Type S and I think I made a great choice. But the passenger side headlight low beam is not working. First guess is that the bulb is not good. Dealer is asking $190 for each bulb replacement. If I have the bulb, they still ask for $140 for the installation. I ordered the Xenon bulbs from Ebay but need some instructions/advice on its installation. Has anyone done that yet? can I get a walk through? I will really appreciate any help.
Thanks in advance.
Old Oct 29, 2007 | 08:03 AM
GreenMonster's Avatar
Headlight removal instructions are here:
https://acurazine.com/forums/showthr...dlight+removal
Getting the helms manual (where those scan are from) is probably a good idea if you're going to do a lot of work on the car yourself. https://acurazine.com/forums/showthread.php?t=178375
Oh, you might want to switch the old bulbs from side to side to make sure it's just the bulb and not the ballast that went out.
Old Nov 7, 2007 | 03:17 PM
zshan1979's Avatar
5th Gear
Headlights work fine.. but RoadLamps don't..
Thanks for the Help.. I successfully installed new low beam bulbs and saved my self at least $200 for installation.
I used 10000K and they look awesome..
But my road lamps dont turn on.. does any one know what kind of bulbs they use? and is there a manual to change its bulbs?
Old Nov 7, 2007 | 04:24 PM
Weavz's Avatar
Finally get to do this! SO Sorry it comes at your expense though...in the upper right, there's a "SEARCH" Feature, do that before posting.
How'd I do guys? Was I too rough? I felt like I went easy on him...
Welcome to Acurazine, BTW
Old Jan 28, 2008 | 09:12 AM
evertp1's Avatar
Pushing 200
you need a DRL fuse. check the fuse to make sure its not blown
acuraST
Sep 17, 2015 02:31 AM
theinsvnity
Sep 10, 2015 10:22 PM
spiel08
Sep 7, 2015 08:19 PM
brjones9
Sep 3, 2015 07:30 PM
voigt
Sep 2, 2015 10:44 PM
