Help with fog light replacement
Old Mar 18, 2002 | 06:39 PM
NoleCLS's Avatar
Okay, I know I'm not the most mechanically inclined, but I figured this would the a good first mod since I can't stand the damn fogs in our car. So I ordered the PIAA 19224 and got them today. I read the post on FAQ web site on how to replace them but I can't even get to the damn screw to take the things out let along get it back in?!?!? What is the secret here or is there another way of doing it?? And for those who want to laugh at me, go ahead, I don't mind being the butt of the joke as long as I get these stupid fogs out!!!!
Old Mar 18, 2002 | 06:53 PM
AztecRol's Avatar
The Screeching Toyo's
I got under the car and took one of the plastic "push through" pegs that holds the black plastic cover to the bumper. I then pushed it aside and it exposed the back of the fog. I just twisted the back of the light socket and replaced the bulb. Making sure I never touched the PIAA with my bare hand. It works for both sides. I hope this helps. I don't have any pics to post, so if this seems confusing let me know, and I will try and explain it better.
Old Mar 18, 2002 | 07:00 PM
NoleCLS's Avatar
Okay, well that didn't work unless I tried taking th ewrong "Peg" out. I tried prying it out with a flat head screw driver and the head of the peg broke in hafl...:sqnteek:
Old Mar 18, 2002 | 07:25 PM
acura_service's Avatar
www.drippinwet.com
just reach in from the front of the wheelwell area and get at the connectors, you don't have to take out the lamp
Old Mar 18, 2002 | 09:12 PM
NoleCLS's Avatar
Theres no way I can do this. I tried getting my arm in there but theres now way to reach it. Maybe I will just have to buy a longer screw driver and try to take the whole thing out like what is suggested in the faq page. any other suggestions would be greatly appreciated.
Old Mar 18, 2002 | 09:14 PM
NoleCLS's Avatar
Just think.....I was actually thinking about installing an AEM CAI myself too......haha, don't think that ones going to happen since I can't even change a light bulb.
Old Mar 18, 2002 | 09:17 PM
www.drippinwet.com
i did it very easily - twice
Old Mar 19, 2002 | 06:38 AM
Smitty02CLs's Avatar
2002 CLs w/Navi
I hope it's easy , I just ordered the 19169's and will be installing them tomorrow.
Old Mar 19, 2002 | 07:17 AM
Scooter's Avatar
'Cooter
ok, i understand everyone's frustrations if u don't have a long philip's head screwdriver...fortunately, i do, so i can't relate all that much to yer frustrations...i would suggest jack up each side of the car, find where the bulb is socketed into the road lampo housing, and replace the bulb that way...here's a pic that may give u some guidance:
notice the accordian-style wire cover...look for it and trace it to the back of the road lamp housing...there should b a dark red connector from the wires to the grey bulb housing...when u see the grey housing, which is fastened to the road lamp housing, turn the whole grey housing 1/8 of a turn (i think it's a clockwise turn)...carefully pull the housing and the bulb out...examine and take note that u need to pull the bulb straight out and insert the PIAA bulb by pushing it straight in...remember to not touch the bulb with yer fingers...wearing surgical gloves or using a paper towel should b fine...just don't use anything clumsy like a towel!!
u should have little to no problems doing it this way, otherwise get yerself a long neck screwdriver
Old Mar 19, 2002 | 07:34 AM
Speedy3.2CL-S's Avatar
There is a gap under the front bumper where the splash guard meets. It had enough room for me to wiggle my arm into it and get to the socket.
Old Mar 19, 2002 | 10:01 AM
NoleCLS's Avatar
Thanks for all of your suggestions. I really appreciate it. I think today or tomorrow I'm going to go try and buy a Long Phillips head screw driver and try to do it that way. I don't think I would be able to fit my arm through that gap. I saw that gap last night when I was trying to do it, but didn't try it. Thanks again, wish me luck.
Old Mar 19, 2002 | 11:08 AM
sundance_gold's Avatar
To tell you the truth, when I replaced mine, I found it easier to follow the instructions in the owner's manual. Once you locate the 4 (or 6--can't remember off the top of my head) "screws", you simply pull down the plastic, twist the bulb assembly and the bulb and the wiring comes right down.
Old Mar 19, 2002 | 11:21 AM
Shawn S's Avatar
The easiest way without getting your knuckles bloody is to just take the ENTIRE piece out like Scooter posted.
All you need is a LONG Phillips screwdriver and a flashlight to see the screw head and you will have both out from the FRONT of the car in 2-minutes.
The 2003 is the same way for removing that FAKE intake thing.
Shawn S
Old Mar 19, 2002 | 11:38 AM
AztecRol's Avatar
This is what I did, I just figured that you only really need to take one out. I think it is the peg that he broke. You need to take a small flat head screw driver and be GENTLE!!! You have to hold the main part of the peg as you try and pry the middle part out. Sorry you are going through so much trouble. Only took me 5 minutes to do both sides.
Old Mar 19, 2002 | 01:36 PM
Scooter's Avatar
'Cooter
do yourselves a favor and get the long neck screwdriver...here's y...first of all, better leverage (u take out the housing and are not in awkward body positions, so u can work calmly and efficiently)...second, better testing (u can test the light before putting it into the housing and risk scratching the coating if u need to take the bulb out of the housing only to reinstall it later)...third, better execution (u can SEE what u're doing...u'll find that since the PIAA's are bigger than stocks, they're more difficult to put in...and u DO NOT want to scratch the blue coating while installing, b/c the heat will melt around the scratch where the coating flakes off...u wanna take yer time and install CAREFULLY...what better way to do that than to b sitting properly and watching what yer doing.
just a suggestion
Old Mar 19, 2002 | 01:39 PM
AztecRol's Avatar
just a suggestion
He should know, he is one of the EXPERTS in this field!!!!!
Old Mar 19, 2002 | 01:54 PM
Scooter's Avatar
'Cooter
that's bout all im an expert at
Old Mar 19, 2002 | 05:40 PM
www.drippinwet.com
i can change both bulbs in less than a minute, there is NO NEED TO REMOVE THE LAMPS - they come right out
Old Mar 20, 2002 | 08:31 PM
NoleCLS's Avatar
just a suggestion
Well......I thank all of you for your suggestions....but I am going to go get a long neck philips and try it this route. It rained today so I didn't get a chance to try. Will keep you updated.......it will be pretty amazing if I actually get this completed!!! Thanks again
Old Mar 21, 2002 | 06:22 AM
2002 CLs w/Navi
He is right guys, I changed mine last night in about 3 min, no need to remove the lamps
Old Mar 21, 2002 | 07:24 AM
Scooter's Avatar
'Cooter
i reiterate my earlier points, especially the 1st one...look, there are a few ways u can go about changing the road lamps...u wanna do it rght?? TAKE YER TIME and do it my way...who cares if it takes 1 minute, 3 minutes, an hour??? slow and steady wins the race!!
Old Mar 21, 2002 | 05:51 PM
www.drippinwet.com
scooter there is nothing bad about not taking out the lights, you reach in twist, pull out (plenty of slack) - reinstall, why would you want to make more work for yourself?
its not wrong or right, its just easy
Old Mar 21, 2002 | 09:26 PM
CharlesNguyen's Avatar
I agree that the easiest way is take the lamps out w/ a long philip screwdriver, 30 sec per sides (seriously), and U can take your sweet time putting the bigger Piaa bulb in...
Much easier ....
Old Mar 21, 2002 | 09:33 PM
gto2050's Avatar
Someday pigs WILL fly!
I love reading this stuff! I tried Shawn S' way and turned that screw for what seemed like a half hour and nothing ever came loose. Then I tried to just reach up in there and it couldn't have been easier. Oh... and yes, I did my own CAI! Didn't have to use any tools called "thingy's" either. (Sorry Amir).
Old Mar 21, 2002 | 09:57 PM
Shawn S's Avatar
You only need to turn the screw about 5 or 6 turns.
It has a capture device on it and will NEVER completely come out and get lost.
You only need to back it out about a 1/4 inch and the entire lens assembly can be pulled right out through the opening.
The screw will still be in place on the back of the lens housing ready to be turned tightly back in place.
VERY EASY !!!!!!!
Until you do it you won’t understand how easy it is.
No need to grope around under the car or shove your hand through confined spaces.
Shawn S
See the photo……the screw is still in place.
Old Mar 21, 2002 | 10:01 PM
www.drippinwet.com
Shawn S
shawn, whats so hard about doing it with your hands, i just bent down and reached in and twisted, removed, replaced, reinserted
Old Mar 22, 2002 | 02:22 AM
kHmER Co's Avatar
mister D
damn.. you are machanically inclined
Old Mar 22, 2002 | 05:53 AM
www.drippinwet.com
remember i'm not a tech, i'm a paper pusher
Old Mar 22, 2002 | 08:12 AM
gto2050's Avatar
VERY EASY !!!!!!!
Shawn S
I'm driving to your house and you can show me in person.
Old Mar 22, 2002 | 09:14 AM
Shawn S's Avatar
I’ll be home all afternoon tomorrow giving baby the first coat of ZAINO and I’ll be trying out this new ZFX “quick-dry” stuff.
Probably a couple of coats Sunday too.
ZAINO RULZ !!!!!!!
Shawn S
Old Mar 22, 2002 | 09:23 AM
4pumpedCL's Avatar
Honkey
Just take the front bumper off, that makes it much easier.
Old Mar 22, 2002 | 01:15 PM
dmcconnell's Avatar
Well, I have tried it BOTH ways, and I agree totally with Scooter & Shawn S. Get a #1 phillips head (or a #0 if you can find it) with at least 6" blade. I can't believe Sears doen't carry one, but True Value does. I also ran into the continual turning to no avail. This was because I had #3 phillips head screwdriver which is too large to seat itself into the screwhead.
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
theinsvnity
Sep 10, 2015 10:22 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
