Help with changing the high beams
Old Apr 8, 2002 | 09:09 AM
JasonT's Avatar
I got some Piaa high beam bulbs, & went to change them. I was a little suprised at how hard it looks. I decided I didn't have the time to mess with it. So my question is are there any instructions on how to change them? I looked in the helms & all it says is too loosen the 3 screws, & twist the bulb out. It doesn't say how to remove the items in the way of those screws, any input would help alot.
I would do a search if it was enabled
Old Apr 8, 2002 | 09:18 AM
Dom418's Avatar
I LOVE MY CAR
Re: Help with changing the high beams
I didn't have to remove ANY screws !? :sqnteek:
The only thing I had to remove was the Fluid reserve bottle on the Driver side and that took all of 30 seconds....
Old Apr 8, 2002 | 09:26 AM
juniorbean's Avatar
Re: Re: Help with changing the high beams
Same here. The fluid reserve took the longest to get seated back into its grooves, but that was all I had to remove. Both bulbs tooks about 3 min. total, with most of that for the fluid reserve bottle.
JasonT... it tells you in the manual how to replace the bulbs. It's a simple twist of the bulb and removal of the harness... should take no longer then 5 min. at the max.....
Old Apr 10, 2002 | 08:42 AM
JasonT's Avatar
Ok, the helms manual is wrong! They say
"loosen the 3 screws, then rotate the bulb 45 degrees counterclockwise, & pull the bulb out"
They didn't mention anything about the removal of the coolant reaserve bottle either.
I tried it again last night, & just twisted the bulbs out, & took the bottle out(I didn't know it just slid out) & bam they are in.
uzzmaan
Aug 4, 2025 08:29 AM
Feb 25, 2020 09:57 AM
phillyguerrilla
Sep 11, 2015 06:39 PM
Aleax
Sep 11, 2015 11:31 AM
theinsvnity
Sep 10, 2015 10:22 PM
