Help with changing the high beams
I got some Piaa high beam bulbs, & went to change them. I was a little suprised at how hard it looks. I decided I didn't have the time to mess with it. So my question is are there any instructions on how to change them? I looked in the helms & all it says is too loosen the 3 screws, & twist the bulb out. It doesn't say how to remove the items in the way of those screws, any input would help alot.
I would do a search if it was enabled
I LOVE MY CAR
Re: Help with changing the high beams
The only thing I had to remove was the Fluid reserve bottle on the Driver side and that took all of 30 seconds....
Re: Re: Help with changing the high beams
Originally posted by Dom418
I didn't have to remove ANY screws !? :sqnteek:
JasonT... it tells you in the manual how to replace the bulbs. It's a simple twist of the bulb and removal of the harness... should take no longer then 5 min. at the max.....
Ok, the helms manual is wrong! They say
"loosen the 3 screws, then rotate the bulb 45 degrees counterclockwise, & pull the bulb out"
They didn't mention anything about the removal of the coolant reaserve bottle either.
I tried it again last night, & just twisted the bulbs out, & took the bottle out(I didn't know it just slid out) & bam they are in.
