Heat
Old Jan 22, 2008 | 06:19 PM
ericb369's Avatar
Heat
It has been pretty cold here in philly the last few days ..the outside temp has read 20 a few days. With my heat on auto and set at 90 it does not seem to produce hot enough air. I am not sure what could be causing this but i feel the heat should be hotter? anybody?
Old Jan 22, 2008 | 06:22 PM
rush's Avatar
03 acura cl type s
nothing just warm the car 4 10mins before driving it
Old Jan 22, 2008 | 06:31 PM
ericb369's Avatar
This is after the veh has been warmed up the temp gauge is always the same on my car summer/winter it is always a lil below half..
Old Jan 22, 2008 | 07:19 PM
ll1l2l1l2lll's Avatar
w202 on carlssons
i think its just 'cause its so cold out and your car itself (big chunk of heavy metal) is cold and a mini heater won't do enough. its like blasting your AC on a winter day, its cold as hell. but on a summer day, its whatevers.
Old Jan 22, 2008 | 08:21 PM
mclarenf3387's Avatar
Make sure you have enough coolant in the car first, then from there you start troubleshooting if there really is a problem or not. Also get a thermometer and measure the actual temp coming out of the vents.
Old Jan 22, 2008 | 08:30 PM
TOPHER33884's Avatar
It happened to me around 2 years ago. Mclarenf3387 is correct, check your coolant level.
Old Jan 22, 2008 | 08:40 PM
visuelz's Avatar
East Coast Crew
Hopefully the temperature isn't normally set to 90 after you find out what is causing the problems, otherwise people might start to die inside =x
Old Jan 22, 2008 | 08:44 PM
02CLNOS's Avatar
take it to a shop and have the coolent evac-ed and recharged. that will help and in the summer.. your nipps will cut glass.
Old Jan 22, 2008 | 09:24 PM
ericb369's Avatar
ok thanks for the suggestions
Old Jan 22, 2008 | 09:47 PM
Your thinking of the refrigerant thats in the A/C system. That won't help him with this problem. You can drain the cooling system and refill it with fresh coolant though. Coolant does degrade over time and raises the freeze temprature and lowers the boil temprature of the coolant.
Old Jan 23, 2008 | 08:16 AM
Moodist's Avatar
If the coolant checks out fine, your thermostat might not be working properly.
Old Jan 23, 2008 | 08:53 AM
dwest1023's Avatar
Also if nothing else shows a problem, then your blend doors might not be working properly. If you have had the system flushed recently you probably have air in your system. Even some dealers don't do the job right.
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
TL14
Sep 24, 2015 04:37 PM
