Heat
Heat
It has been pretty cold here in philly the last few days ..the outside temp has read 20 a few days. With my heat on auto and set at 90 it does not seem to produce hot enough air. I am not sure what could be causing this but i feel the heat should be hotter? anybody?
w202 on carlssons
i think its just 'cause its so cold out and your car itself (big chunk of heavy metal) is cold and a mini heater won't do enough. its like blasting your AC on a winter day, its cold as hell. but on a summer day, its whatevers.
Make sure you have enough coolant in the car first, then from there you start troubleshooting if there really is a problem or not. Also get a thermometer and measure the actual temp coming out of the vents.
Originally Posted by 02CLNOS
take it to a shop and have the coolent evac-ed and recharged. that will help and in the summer.. your nipps will cut glass.
Also if nothing else shows a problem, then your blend doors might not be working properly. If you have had the system flushed recently you probably have air in your system. Even some dealers don't do the job right.
