Headers?!!
Whats up with RDX owners?
Two flex pipes. Stay away.
DFW AREA,
Are these any good i wanna try em
http://cgi.ebay.com/ebaymotors/98-02...item2a03551575
"DD" Designated Drinker
i got the DC Sport ones they fit just fine for me and they were 400ish shipped. and they still look brand new had them for over a year now.
but never buy crappy stuff. it wont fit right, crack or leak and theres all kinds of other issues
3.7L Nitrous Breathing CL
Got SS obx's,been on for 2 months.
bolted up fine
reused stock exhaust manifold gaskets.
used that gasket maker stuff for the header to cat gasket.
no leaks still look good.
And give you added power.
got mine for $265 shipped with some bargining.
It's possibly the best option.
price vs design.
cheapest one flex pipe header and I have nothing bad to say yet.
bolted up fine
price vs design.
wham bam thank you ma'am
two flex pipes suck
u should only need one. if u have another one, thats a cheap fix bc it doesnt fit right
the fist flex pipe tends the blow out really fast, but then again any cheap flex pipe will. like the ones that they use on cheap headers like this
and im about 100% sure ur gonna have exhaust resonance bc they use thin metal for the headers and down pipe.
time will tell and ppl have had complaints with the dual flex pipe headers. just wait and see.
and if im gonna be putting on headers and dealing with rusted bolt and tight space. im gonna do it once and do it right.
http://cgi.ebay.com/ebaymotors/98-02...Q5fAccessories
http://cgi.ebay.com/ebaymotors/DC-SP...Q5fAccessories
cheapest i found on ebay WITHOUT that useless mini plex pipe. There shouldnt be a flex pipe in there at all. It should all be straight pipe. What MIT grad thought it would be a good idea to put that retarded mini flex pipe in there anyway????
its obvious that they're copying compechs design right? how hard is it to make a simple bend??
I personally bought the SS autochrome ones when i had the chance. $130 shipped was great. Had them on for almost 2 years with no problems. I used fel-pro manifold gaskets to make up for any inconsistancies at the flanges.....no leaks. I also used fel-pro "donut" gaskets for the J-pipe and converter flange. Havent had any problems whatsoever. Maybe i got lucky.
One other thing i noticed, none of the cheap-o's have the bend for the 6 speed guys. if anyone that has a six speed and wants headers, dont buys these....they wont fit.
Alright Guys ijust installed the Cheappy headers and they work great !!
But the mini Flex Pipe im just gonna replace it with a pipe!
but they dont make much of a diffrence as my dc headers though
!iwill post pics up later
You really should have a flex pipe there. Just replace it with a higher quality unit.
'03 ABP YA4-S 6MT
the rear one needs to be on because it attaches to the rest of the exhaust.
Just for clarification:
Flex pipes are not *designed* to correct fitment issues, they are very prone to premature failure if mounted with force on them. Flex pipes are intended to be used to isolate the engine from the exhaust to reduce vibration and noise. There will not be more than a 1-2mm variation in bracket position on any OEM exhaust/header, and this variation will be taken up by the mounting brackets. There is also a tolerance for the full system (from header to exhaust tip), that is taken into consideration.
I Just welded a straight pipe where the mini flex pipe was and now experiencing vibration issues!!
gonna replace the mini flex pipe with a higher quality one?
the front flex pipe (the smaller one as he says) is not necessary if they weld it while it's on the car, imo. the front and rear headers shouldn't be moving independently of each other while bolted to the engine.
the vibrating nasty sound started whn i removed the Mini Flex Pipe!
ithink im just gonna end up buying a good mini flex pipe
sounds sometime's at idle, whn accelerating, and at a stop at a stop light ect.
OK i Found out wht was cause the header to vibrate!!!
it was rubbing on a piece of frame on the bottom car so i cut a 2inch metal tht was rubbing and fixed woo hoo!!
Its a Great Gain With Those headers!
