Headers?!!
Old Mar 2, 2010 | 11:45 AM
SexyCLS's Avatar
Headers?!!
Are these any good i wanna try em
http://cgi.ebay.com/ebaymotors/98-02...item2a03551575
Old Mar 2, 2010 | 12:21 PM
Nitin's Avatar
But I just got here
I've never heard of Speed Daddy. For only $100 I have a feeling they'll never fit perfectly though.
Old Mar 2, 2010 | 12:36 PM
civicdrivr's Avatar
Two flex pipes. Stay away.
Old Mar 2, 2010 | 12:41 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
There was some a little while back on ebay getting sold for $69.keep shopping if your trying to get cheap one's.
Old Mar 2, 2010 | 02:42 PM
98JDMCL's Avatar
Justin's
Never go cheap.
Old Mar 2, 2010 | 02:54 PM
BlackBettyR1's Avatar
Originally Posted by 98JDMCL
Never go cheap.
Fast, Reliable and Cheap. Pick any two!
Old Mar 2, 2010 | 04:30 PM
dfv3.2CL-S's Avatar
Dont buy crap!! Stick to the known stuff as Comp Tech and XS.
Old Mar 2, 2010 | 04:50 PM
duyx817's Avatar
DFW AREA,
Originally Posted by SexyCLS
we dont know if its good because no one ever tried it.. but maybe you can be the first?
Old Mar 2, 2010 | 05:28 PM
Nicks01CL-S's Avatar
"DD" Designated Drinker
i got the DC Sport ones they fit just fine for me and they were 400ish shipped. and they still look brand new had them for over a year now.
but never buy crappy stuff. it wont fit right, crack or leak and theres all kinds of other issues
Old Mar 2, 2010 | 05:32 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
agreed.... get DC headers. for the price vs quality it's a no-brainer
Old Mar 2, 2010 | 05:42 PM
Got SS obx's,been on for 2 months.
bolted up fine
reused stock exhaust manifold gaskets.
used that gasket maker stuff for the header to cat gasket.
no leaks still look good.
And give you added power.
got mine for $265 shipped with some bargining.
It's possibly the best option.
price vs design.
cheapest one flex pipe header and I have nothing bad to say yet.
Old Mar 2, 2010 | 08:08 PM
SexyCLS's Avatar
Not be against everyone's decision im gonna buy em and then post on here how they work!!
Old Mar 2, 2010 | 08:14 PM
madmuzik09's Avatar
Waits for Shakira in his
Good luck
Old Mar 2, 2010 | 08:17 PM
SexyCLS's Avatar
Originally Posted by madmuzik09
Good luck
Thanks Im Not sure if yall are interested in the out come of the headers?
Old Mar 2, 2010 | 08:19 PM
madmuzik09's Avatar
I am
Old Mar 2, 2010 | 08:27 PM
SexyCLS's Avatar
ight kool i'll put the order tomorrow midday and then we wait lol
Rajca's Avatar
wham bam thank you ma'am
two flex pipes suck
u should only need one. if u have another one, thats a cheap fix bc it doesnt fit right
the fist flex pipe tends the blow out really fast, but then again any cheap flex pipe will. like the ones that they use on cheap headers like this
and im about 100% sure ur gonna have exhaust resonance bc they use thin metal for the headers and down pipe.
time will tell and ppl have had complaints with the dual flex pipe headers. just wait and see.
and if im gonna be putting on headers and dealing with rusted bolt and tight space. im gonna do it once and do it right.
Old Mar 2, 2010 | 08:34 PM
CLPimpin114's Avatar
Tokin up in
I am
X1 Thats beacuse i too looked at these
Old Mar 2, 2010 | 09:19 PM
RoccoRock's Avatar
http://cgi.ebay.com/ebaymotors/98-02...Q5fAccessories
http://cgi.ebay.com/ebaymotors/DC-SP...Q5fAccessories
cheapest i found on ebay WITHOUT that useless mini plex pipe. There shouldnt be a flex pipe in there at all. It should all be straight pipe. What MIT grad thought it would be a good idea to put that retarded mini flex pipe in there anyway????
Old Mar 2, 2010 | 09:28 PM
Rajca's Avatar
fitment problems. thats why they have two flex pipes. fitment problems
Old Mar 2, 2010 | 09:36 PM
RoccoRock's Avatar
its obvious that they're copying compechs design right? how hard is it to make a simple bend??
I personally bought the SS autochrome ones when i had the chance. $130 shipped was great. Had them on for almost 2 years with no problems. I used fel-pro manifold gaskets to make up for any inconsistancies at the flanges.....no leaks. I also used fel-pro "donut" gaskets for the J-pipe and converter flange. Havent had any problems whatsoever. Maybe i got lucky.
One other thing i noticed, none of the cheap-o's have the bend for the 6 speed guys. if anyone that has a six speed and wants headers, dont buys these....they wont fit.
Old Mar 2, 2010 | 09:43 PM
98JDMCL's Avatar
Justin's
well you sure cant get all 3
Old Mar 12, 2010 | 07:34 PM
SexyCLS's Avatar
Alright Guys ijust installed the Cheappy headers and they work great !!
But the mini Flex Pipe im just gonna replace it with a pipe!
but they dont make much of a diffrence as my dc headers though
!iwill post pics up later
Old Mar 13, 2010 | 02:16 AM
victorvu's Avatar
you never know if the headers are any good look at xs some people say they suck and still now people want it you have to try it. see if it fits might be another solution to headers.
Old Mar 13, 2010 | 01:00 PM
civicdrivr's Avatar
You really should have a flex pipe there. Just replace it with a higher quality unit.
Old Mar 13, 2010 | 02:10 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
the front flex pipe (the smaller one as he says) is not necessary if they weld it while it's on the car, imo. the front and rear headers shouldn't be moving independently of each other while bolted to the engine.
the rear one needs to be on because it attaches to the rest of the exhaust.
Old Mar 13, 2010 | 03:25 PM
ML03CLS's Avatar
Just for clarification:
Flex pipes are not *designed* to correct fitment issues, they are very prone to premature failure if mounted with force on them. Flex pipes are intended to be used to isolate the engine from the exhaust to reduce vibration and noise. There will not be more than a 1-2mm variation in bracket position on any OEM exhaust/header, and this variation will be taken up by the mounting brackets. There is also a tolerance for the full system (from header to exhaust tip), that is taken into consideration.
Old Mar 13, 2010 | 04:45 PM
SexyCLS's Avatar
I Just welded a straight pipe where the mini flex pipe was and now experiencing vibration issues!!
gonna replace the mini flex pipe with a higher quality one?
Old Mar 13, 2010 | 04:50 PM
Rajca's Avatar
all u need is ONE flex pipe. right before the cat on the j pipe
Old Mar 13, 2010 | 06:35 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
when does it vibrate? on throttle, idle, etc?
could be that it just needs to be rewelded, but done better..
Old Mar 13, 2010 | 07:56 PM
civicdrivr's Avatar
I just reread what he said and he mentioned the mini flex pipe. I thought he was talking about the main flex pipe, which is recommended.
Old Mar 15, 2010 | 09:10 AM
SexyCLS's Avatar
the vibrating nasty sound started whn i removed the Mini Flex Pipe!
ithink im just gonna end up buying a good mini flex pipe
sounds sometime's at idle, whn accelerating, and at a stop at a stop light ect.
Old Mar 18, 2010 | 12:49 PM
SexyCLS's Avatar
OK i Found out wht was cause the header to vibrate!!!
it was rubbing on a piece of frame on the bottom car so i cut a 2inch metal tht was rubbing and fixed woo hoo!!
Its a Great Gain With Those headers!
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
CLsuperhero
Sep 23, 2015 12:53 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
