head light problems
Old Aug 11, 2004 | 08:55 AM
mretif's Avatar
head light problems
i know others have had problems with there headlight not turning on but i want to know if anyone has gotten it fixed under warrenty.
sidenote, would the heated seat be under warrenty also?
Old Aug 11, 2004 | 09:10 AM
NOLACLS's Avatar
Yes it should all be under warrenty if you have not changed your headlights any or tampered with the seats. I have ahd 2 headlights go out and it was something called an inverter both times. If it is the bulb it will not be covered.
Old Aug 11, 2004 | 09:12 AM
mretif's Avatar
i just changed out the high beam bulb, i assume i am ok but should i put the stock bulb back in?
Old Aug 11, 2004 | 09:13 AM
mretif's Avatar
NOLACLS, i just saw that you were from new orleans, i was just there this weekend
Old Aug 11, 2004 | 09:16 AM
NOLACLS's Avatar
Well it depends on your dealer...if they see the high beams changed and they are not cool about stuff...they will blame it on that I would bet. Is it just the low beam that doesnt come on or both high and low beam?
Yeah it was a nice this weekend here..weather wise.
Old Aug 11, 2004 | 12:55 PM
mretif's Avatar
it is just the right low beam headlight that i have a problem with, i assume they are mod friendly because i got new transmission with headers and intake.
Old Aug 11, 2004 | 01:10 PM
fuzzy02CLS's Avatar
Your high beam bulbs have NOTHING to do with the HID low beams. The HID lights run on a different system. You do not touch anything that has to do with the HID lights when replacing the high beam, bulbs. So you should be fine with that.
Old Aug 11, 2004 | 01:23 PM
sundance_gold's Avatar
how difficult/costly to replace a low beam?
It is hard to replace the HID lights (is it a DIY?)? Not sure if you can just replace a bulb or it its a whole unit.
My lights are fine but I've always wondered how much it will cost me when one of these blows.....
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
Ny1718
Sep 11, 2015 09:21 AM
