Has anyone had this problem
Old Jan 10, 2004 | 08:21 AM
CBR1100XX's Avatar
Way Fast Whitey
My driver side window seems to be rolling down slower than the passenger. it is actually a noticable difference. Am i the only one? I have 22k miles on the car, will Acura warranty the issue?
Old Jan 10, 2004 | 11:08 AM
CL P Diddy's Avatar
yeah,yeah,uh,huh,wh,what
Take it in. I'm sure this is a warranty item. Sounds like your motor is going bad. I had that happen when I had my Accord.
Old Jan 10, 2004 | 11:14 AM
CLpower's Avatar
teh Senior Instigator
This is very common on hondas, the motor is going bad. What you should do is grease up the sills. You can use something like KY or Astroglide (or honda even makes a silicone spray. Spray it in the creases it should speed it up.
Old Jan 10, 2004 | 06:05 PM
njtls2's Avatar
17 and loving it
mines slwoer when its going auto down
Old Jan 10, 2004 | 07:28 PM
greyjhu's Avatar
DC Cruiser
My passenger side window used to go up slower than my driver. My dealer lubed up the windows, and both roll up at the same rate. Warranty item-
Old Jan 12, 2004 | 09:25 AM
2canoe's Avatar
I have a 99CL 2.3 engine was noisey at 20k miles replaced engine at 40k miles. noisy again at 60k miles. any input ?
Old Jan 12, 2004 | 06:00 PM
CBR1100XX's Avatar
Way Fast Whitey
I took care of it. I pulled the door panel and lubed it myself. This happened to me in the past on my 2001 lightning. That time it happened pretty early so it was a warranty item.
Old Jan 12, 2004 | 06:32 PM
CLpower's Avatar
you didn't need to pull the door panel off man
Old Jan 12, 2004 | 09:56 PM
highwire's Avatar
Dealer gave me a big honkin' tube of Sil-glide - a silicone-based lubricant gel. Make my studdering driver's window as smooth as silk, and a lot faster too.
Old Jan 13, 2004 | 05:23 PM
CBR1100XX's Avatar
Way Fast Whitey
I lubed the rails inside the door.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
