Got my UR Crank pulley installed (review)
Old 12-28-2003, 04:30 PM
  #41
Chaptorial's Avatar
Nice review. Looks like a future mod for me.
Old 12-28-2003, 04:37 PM
  #42
typeR's Avatar
Originally posted by scalbert
There probably are things that could be done. You could delay the shift signals to always shift higher. You could also alter the line pressure control solenoid to gain higher line pressure for firmer shifts.
No one has really delved into the electronics of the 5AT. But things could be done.
ooooh i like the sound of that..let's talk ..also couldnt we delay the signal to the ecu that 7200 rpms have been achieved?
Old 12-28-2003, 10:12 PM
  #43
TL_Type_S's Avatar
Two more things I've noticed w/ my pulley:
1) At idle (in park) .. i watch my tach closely and i can see it has become more "jittery" .. compared to pre-pulley where it was smooth and would slowly lull up and down (tiny amounts) at idle.
2) At WOT .. everytime! i can feel a little vibration from the engine at vtec engagement (~4800 rpms) and I can hear more engine noise .. a little higher pitch ..
3) VTEC zone really does seem to have improved noticeably .. may be my imagination, but it's my best comparison to pre-pulley.
Old 12-29-2003, 05:06 AM
  #44
scalbert's Avatar
I no longer care how the ECU controls the shift since I have a stick. But when these other projects are complete I will look into the controls and see what can be done.
As for holding a gear longer; that could be done but may require multiple signal clamps. Also, how would extra fuel be added as the revs kept climbing?? If you fooled the ECU into thinking that it was still at 6900 RPM and not climbing but the revs were actually 7500 RPM, you would be supplying about 8% less fuel than really needed. Also, the ECU may do some unusual things such as shift since the rate of change for the RPM has gone flat.
Lastly, is it really needed?? Torque is already dropping off to a point where, even with the reduction through gearing changes, the shift may provide more wheel torque.
Old 12-29-2003, 05:09 AM
  #45
scalbert's Avatar
You may want the ECU to re-run the idle learn procedure. Just pull the (I believe) #13 fuse on the passenger side fuse panel for about ten seconds. Start the car and let it warm with all accessories off (AC and stereo) and let the cooling fans cycle three times.
This may help with the idle issue.
Old 12-29-2003, 06:15 PM
  #46
TL_Type_S's Avatar
Scalbert, thank you for the advice:
When i restart the car .. should I do this w/o the fuse installed? Or should I pull the fuse out, wait ten seconds, and then re-install the fuse and start the car? Thanks
Raj
Old 12-29-2003, 09:47 PM
  #47
scalbert's Avatar
Pull the fuse, wait ten seconds and re-install the fuse. The car won't run without that fuse.
Old 12-29-2003, 11:14 PM
  #48
CYBERCLS's Avatar
TL_TYPE_S
I just got my pulley installed today and just like ur first post I agree 100% with everything you said. Will I eventually get more out of the pulley or is this it? Just higher revs and basically thats it? Great review! Plus did u unhook ur battery and reconnect it? Does this really do SOMETHING?? hmm..
Old 12-30-2003, 09:56 AM
  #49
'Big Daddy Diggler'
bigman's Avatar
try it and let us know.
Old 12-30-2003, 12:41 PM
  #50
CYBERCLS's Avatar
Thanks I will try it. When you park the car after driving the shit out of it, do you have to let it sit for the rest of the day? Or can I let it sit for a couple more hrs and then drive it later that day?
Bigman empty your mailbox
Old 12-30-2003, 12:46 PM
  #51
scalbert's Avatar
If you dance around it during a full moon and spill the blood of a lamb you not only will have a faster car; you might also go to jail.
The thing I find interesting is that fact that the adaption (transmission wise) required a reset. It will be the same soon enough so save the time in reseting the clock, radio pre-sets, memory seats, etc. If reseting the ECU is good, I bet the spiralmax is GREAT.
Old 12-30-2003, 01:23 PM
  #52
Homeless
chef chris's Avatar
Spiralmax......comes with a free can of SPAM.
Steve, does underdriving the pulley's make the alternator put out less juice?(dim the lights a bit, etc).
Old 12-30-2003, 01:39 PM
  #53
scalbert's Avatar
If the accessory pulleys are underdriven then yes, the alternator will produced less output. However, unless you have a large system installed it most likely would not be a problem.
Old 12-30-2003, 04:47 PM
  #54
TL_Type_S's Avatar
CyberCLS...
I'm gunna try Scalbert's suggestion, but probably won't bother pulling the battery and plugging that back in again .. his logic makes sense.
I'll let you know after the ECU reset..
hey, do you notice any increased noise from the engine in the cockpit under WOT .. any new vibrations?
Old 12-31-2003, 07:24 AM
  #55
CYBERCLS's Avatar
TL_TYPE_S
I do notice the slightest sound. Car def runs smoother and no vibrations at all. Def let me no about his suggestion. You have a week on me so if you notice any difference at all with the crank please let me no. Do you notice any sound or anything?
Old 12-31-2003, 09:33 AM
  #56
'Big Daddy Diggler'
bigman's Avatar
You're a dick :P
Old 12-31-2003, 09:40 AM
  #57
scalbert's Avatar
Originally posted by bigman
You're a dick :P
:P
Old 01-01-2004, 01:51 PM
  #58
TL_Type_S's Avatar
TL_TYPE_S
I am also noticing a little harsher start-up when the engine is cold. It's perfectly fine after the engine's been warmed up. however, after sitting out in the cold overnight, it seems like there's more of a clatter in the engine bay when I start it up. Wonder if that has to do w/ the lower weight on the crank shaft.
Old 01-01-2004, 02:43 PM
  #59
Full-Time IDIoT---DoH!!!
DISRUPTV's Avatar
steve
a hypothetical question...if u had decided to go NA instead of boosted, would u have purchased UR pulleys?
Old 01-01-2004, 03:46 PM
  #60
scalbert's Avatar
Most likely...
Old 01-02-2004, 02:00 PM
  #61
EricL's Avatar
Less damping on the crankshaft == more noise.
The stock piece had a chunk of rubber for NVH (noise, vibration, harshness) *and* torsional vibration suppression.
Old 01-02-2004, 05:02 PM
  #62
TL_Type_S's Avatar
Interesting.. thanks for the input.
BoricuaTL
04-08-2016 01:08 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
whitesoxsfan12
09-13-2015 02:09 PM
iCrap
09-11-2015 06:21 PM
NSolace
09-03-2015 08:14 PM
Quick Reply: Got my UR Crank pulley installed (review)
