Got my PIAA bulbs
Old Jun 16, 2005 | 01:26 AM
LaKings84's Avatar
Got my PIAA bulbs
Hey guys first off I am sorry, I tried using the search feature but I cant find any instructions or any help on how to install my fog light bulbs.
I got the bulbs today, but I dont know how to get to the bulbs. I have an 01 CL-S with OEM fog lights. I havent tried looking in the manual, but my car came with a 02 TL manual, so I am not sure if its the same.
Any help would be greatly appreciated. Thanks.
- V
Old Jun 16, 2005 | 08:24 AM
phipark's Avatar
Not Asian
Search harder.
There is a screw you can access from the inside of the grill towards the raod lamps. Use a long phillips screw driver. Unscrew, then pop the lamps out.
Old Jun 16, 2005 | 08:25 AM
RaviNJCLs's Avatar
It's really easy. These are the instructions I followed. Click here
Just take your time removing the screw, since the head is really small and if the Phillips head screw driver is too large, you won't catch the head.
Also, the bulb may be a hair too large. Be careful putting it in to the housing. I used a Dremel and just opened it a bit.
Good luck.
Old Jun 16, 2005 | 08:43 AM
kholla's Avatar
AVID HATER
If you really want to change it without messing anything up. Put your car on a jack. Lay on your back and you can remove the bulb itself without taking out the housing. I found this easier since you sinply have to turn the bulb and harness counter clock wise, change the bulb and put it back in( no messing with screws and foglight housing) The directions are in the book. I'll check on my lunch break and tell you wat page. FYI I changed my bulbs 2 times. 1nce with a screwdriver and the scecond time following the directions. It prefer to do it this way
Old Jun 16, 2005 | 08:44 AM
kholla's Avatar
AVID HATER
^^^^^^jack the front of the car
Old Jun 16, 2005 | 02:54 PM
LaKings84's Avatar
Thanks so much guys. RaviNJCLs thanks for the pics, and phipark thanks for the advice to search harder, that didnt come to me.
Old Jun 16, 2005 | 03:59 PM
phipark's Avatar
Not Asian
j/k sheesh
Also, I think it's harder to go from underneath because you have to remove the splash gaurd.
Old Jun 16, 2005 | 05:00 PM
andre's Avatar
FWD tuna boat
Originally Posted by phipark
j/k sheesh
i've done it twice already...both times from below the front bumper. just removed one clip on each side, slid my hand under the guard, removed the old bulb, and insterted the new one.
less than 5 minutes to replace both.
Old Jun 16, 2005 | 05:04 PM
andre's Avatar
FWD tuna boat
i'm curious...what replacement bulbs did you install?
i bought piaa 19227, but they were slightly big and had to open the housing a bit. my first pair were other (19173 i think) piaas and fit perfectly (same size as oem bulbs).
these 19227 xtreme white are light blue, which i cant stand. once i find WHITE bulbs, i'm going to replace these ugly, oversized, purple when off, nasty bulbs.
Old Jun 16, 2005 | 05:05 PM
kholla's Avatar
AVID HATER
j/k sheesh
I'm not that mechanically inclined.
When i did it with a screw driver, one of my lamps never fitted as nicely as it once did
Old Jun 16, 2005 | 05:20 PM
MQMH_03's Avatar
I think the piaa 19224 are the correct bulbs for our foglight housings. Someone back me up on this.
Old Jun 16, 2005 | 05:24 PM
kholla's Avatar
AVID HATER
j/k sheesh
Old Jun 16, 2005 | 05:29 PM
Mike_McCready's Avatar
Much easier on TL
Old Jun 16, 2005 | 09:23 PM
F900's Avatar
Yes they are...but IMO they dont match the HIDs that close. Yes a better replacement then the OEMs but they look too blue.
Old Jun 17, 2005 | 09:13 AM
kholla's Avatar
AVID HATER
^^agrees. I also hate how when the are off you can see the blub. This kinds ruin the whole look
Old Jun 17, 2005 | 10:19 AM
andre's Avatar
FWD tuna boat
my bad, they are 19224, but the 19173 fit better
Old Jun 17, 2005 | 10:21 AM
headersplus's Avatar
I replaced mine using instructions here after doing search. Couldn't have done w/o the instructions here. Had no idea how easy it was.
Old Jun 17, 2005 | 02:20 PM
kholla's Avatar
AVID HATER
^^ told you it was easier than messing with those screws
Old Jun 17, 2005 | 03:22 PM
F900's Avatar
Does anyone make Bulbs that give pure white light and don't look blue lol....
Old Jun 20, 2005 | 02:09 PM
andre's Avatar
FWD tuna boat
i guess not.
every time i ask, i get no response.
purple bulbs suck!
Old Jun 20, 2005 | 02:22 PM
phipark's Avatar
Not Asian
I don't believe so.
Old Jun 20, 2005 | 02:29 PM
AMorgCLS's Avatar
Girls luv me Guys hate me
I dont know if anyone has tried this, but i'm gonna try a bright amber in our road lamps and see how they look at night. I'll keep you guys posted with pics after they're done.
Old Jun 20, 2005 | 02:57 PM
SC2.2CL's Avatar
Hey, I have a LT, but my roomate just got an 01 CL and the fogs don't work. How do you turn them on? I guess that they come on with the parking lights. We have not looked at the fuse box yet, or both of the bulbs could be burned out.
BTW. I just put PIAA Ion Crystal in my TL fogs and they look great, very yellow. I got the Lexus IS 300 look I wanted
Old Jun 20, 2005 | 03:10 PM
AMorgCLS's Avatar
That's exactly the look i'm going for. As from your roommate, the roadlamps automatically come on when you turn the lights on. They dont come on with just the parking lights. Check for a blown fuse, if not, the bulbs could just be completely out.
BTW, do you have any night pics of your fogs with the PIAA Ion Crystals?
Old Jun 20, 2005 | 03:28 PM
AMorgCLS's Avatar
I guess "bgsm1th" beat me to it by 5 months now, and damn they look good. Def going with the PIAA ION Crystal now
Old Jun 24, 2005 | 07:03 PM
SC2.2CL's Avatar
I tried to take pics this weekend, but they dont show the color well. I will try again. Just know that they make the turn signals look oranger, but the fogs look great
Old Jul 6, 2005 | 08:27 PM
SC2.2CL's Avatar
Here are the pics of my TL and my roomates CL. I could not get the bulbs to show their color with a regular picture. Both cars look very yellow, but the CL just does not project that far. Still looks good. The wall picture has the CL on the left and the TL on the right. Both have PIAA Crystal Ion bulbs.
Old Jul 7, 2005 | 03:49 AM
Time For Sleeep's Avatar
That's Racist
I'm likin' how the projection looks on the CL. What bulb did they buy forthat? Was it a perfect fitment?
Old Jul 8, 2005 | 11:35 AM
SC2.2CL's Avatar
The CL (one on the left in the lower pic) has a PIAA Ion Crystal size 168/192. They are also called 19173. I got mine on E-bay here is a link to the bulb Please note that they are not the bulbs in the combined picture on the right. That is my TL with 9006 bulbs, they are much brighter, but the same color. http://piaa.carshopinc.com/product_i...id/42535/19173
hashbrown
Feb 18, 2022 11:20 AM
Avenger411
Oct 11, 2015 03:53 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
ripit
Sep 26, 2015 06:19 PM
eastcoastguy
Sep 23, 2015 06:29 AM
