Gas
Old May 15, 2004 | 04:34 PM
Justin.CL's Avatar
Gas
If this question has already been asked I apologize in advance.
What kind of gas do you put in your car? I usually always stop at the Shell station close to my house and ALWAYS get premium. Friday morning I took my girlfriend's civic in for service and she took my car (01CLS) to work. The gas light was on so I gave her money to fill it up. She got regular. All of last night and today the car does not feel right and the matinence required light is on.
Anybody ever used regular gas (87 octane)? How did the car respond?
Old May 15, 2004 | 05:09 PM
1killercls's Avatar
GEEZER
Premium only NooB..
That is unless you like deminished performance.
Old May 15, 2004 | 05:17 PM
Zapata's Avatar
Cost Drivers!!!!
you can use regular.....the ECM will retarded timing and reduce performance. SHouldn't hurt the car.
Old May 15, 2004 | 07:22 PM
CL Type"S"1's Avatar
A-CL Driver
key word is in there some where!
RETARDED
j/k....throw some oct. booster in there could help?
Old May 15, 2004 | 09:29 PM
Dem1K's Avatar
Got a Job!
dont trip, it wont kill the engine man...just drive the car and finish out the remainder of this gas, and on your next fill up, as well as every other fill up, stick with premium .
Old May 15, 2004 | 09:47 PM
Justin.CL's Avatar
What have I learned from all of this???
DON'T LET MY GIRLFRIEND DRIVE THE ACURA!!!
Two months ago she hit my mailbox with it. I guess I should have known better this time.
Old May 16, 2004 | 12:56 AM
Dark8's Avatar
what about 89 octane?
Old May 16, 2004 | 02:33 AM
WILLDOGS's Avatar
I shave my change purse
91 octane or better ONLY! It's noted in the car manual and inside the gas door.
Old May 16, 2004 | 02:48 AM
chungkopi's Avatar
hail to the victors
i'm thinkin about using 89. gas is too expensive and i don't care about the performance. as long as it doesn't hurt my engine i think i'm going with something cheaper.
Old May 16, 2004 | 03:30 AM
yi_yi's Avatar
hahhaha
Old May 16, 2004 | 09:45 AM
louisn's Avatar
BTW, The maintenance required light is miles sensitive and does no have any diagnostic function.
Old May 16, 2004 | 09:52 AM
mrsteve's Avatar
To turn it off:
1) Car in park, car turned off.
2) Hold both the trip and reset buttons in.
3) Turn key to the "ON" posistion but do not start.
4) Hold the buttons for another 10-12 seconds.
You should be good to go. The light will come on briefly, along with the other dash lights, when you start the car and then go off.
Old May 17, 2004 | 11:54 AM
lead_sled_dog's Avatar
Back to Four Doors
Same here in NorCal. With premium over $2.50/gal, every other tankful is 89. I can feel a small decrease in performance but damn it hurts to spend nearly $40 to fill it up. Plus I drive almost 2K miles per month so it adds up.
Old May 17, 2004 | 12:02 PM
carquest's Avatar
if you read any of the techno-babble on acura's website it claims that the 3.2 has several knock sensors which PREVENT any pre-ignition (knocking & pinging). this system works REGARDLESS of what kind of gas you use. if its true lower octane won't damage the engine. it may not run as fast or idle as smooth but it shouldn't hurt anything.
that's all theory up till now. your one of the 1st test subjects. think of it as crash test dummy training.
Old May 17, 2004 | 01:23 PM
SanMarinoTypeS's Avatar
My service manager suggested I alternate between 89 and 91, I see absolutely no diffrence in performance or gas milage.
xsilverhawkx
Oct 5, 2015 11:00 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
San Yasin
Sep 29, 2015 10:52 AM
