fuel cutoff or what
Old Mar 29, 2005 | 12:50 AM
clsironhead's Avatar
Member this
fuel cutoff or what
today i was on the freeway getting on the on ramp pushing close to redline but, not close like around 6300 rpms on second gear and all of a sudden the power cut . i was thinking that i hit the revlimiter but i know i didnt go that high to hit it. could i be that the fuel was cut off i some form.
Old Mar 29, 2005 | 01:45 AM
sgmotoring's Avatar
Bleed Honda Blue
or what!
Old Mar 29, 2005 | 01:53 AM
mattg's Avatar
rev limiter / fuel cutoff is over 7K rpm's
Old Mar 29, 2005 | 01:59 AM
Member this
i know , i think its 7100. should i just take it in. it did it twice the second time i did it from first to second in the same rpm range (6300). so pissed off .
Old Mar 29, 2005 | 02:01 AM
Member this
could it be a fuel filter problem
Old Mar 29, 2005 | 10:01 AM
typeR's Avatar
if you oil level is low you will get fuel cut when vtec is engaged...and being on a sweeper makes it worse moves the oil to one side of the pan...
Old Mar 29, 2005 | 10:36 AM
Jonesi's Avatar
Check your oil levels..
Old Mar 30, 2005 | 11:44 AM
Member this
ill check it out . thanks guys
Old Mar 31, 2005 | 12:12 AM
Member this
checked the oil level and it was low. i took her for a spin an all feels well thats again.
Old Mar 31, 2005 | 01:39 AM
bigguyonbike's Avatar
13.2 @ 104.76mph
your tires could of broke loose and VSA interrupted your fun .
that happens to me alot.
Old Mar 31, 2005 | 01:55 AM
Member this
i have six speed dont have vsa i think
joflewbyu2
Aug 18, 2019 10:38 PM
LeVeL
Oct 18, 2015 04:19 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
joflewbyu2
Oct 8, 2015 11:16 AM
