Fram Sure Drain
Old Nov 9, 2003 | 01:04 PM
dfv3.2CL-S's Avatar
Fram Sure Drain
Has anyone in this forum used or installed one of these Sure Drain units on a CL. Will this thing work on our car?
Old Nov 9, 2003 | 10:12 PM
AkuraCLS's Avatar
ALi G in the House!
i love that thing!
Old Nov 9, 2003 | 11:41 PM
civic4982's Avatar
SHIFT_over.so.I.can.see
it seems like a great idea.... I wanna get one... how much are they again?
Old Nov 10, 2003 | 02:26 AM
Slimey's Avatar
Where is my super sauce?
Tons of people on the Subaru forums swear by the Fumoto Valve and cannot live without it.
I forgot why, but I remember reading here (on ACL.com) that the Fumoto product was better then the Fram product (maybe it was price?).
I actually use a topsider (I have this Griot's model, but there are others (Pela - available at Marine supply stores) to suction out the oil) -- with Acura's easy placement of the filter, I never really need to get under the car for an oil change.
Old Nov 10, 2003 | 05:41 AM
Caddy©'s Avatar
I have the FUMOTO Valve, but haven't installed it yet. I need to by another gasket before I put it on. Because of the design of the Oil Pan, they will send and extension with it. It sticks out about 3 inches or better.
Old Nov 10, 2003 | 06:46 AM
dfv3.2CL-S's Avatar
is there a Fram Sure Drain unit that will fit our 3.2 engine. The reason I ask is due to the fact that on there application chart our Cl does not appear under Acura. Can someone give me the part number for the CL?
PS How much is the Fumoto valve for the CL?
Old Nov 10, 2003 | 06:49 AM
Slimey's Avatar
http://www.fumotovalve.com/merchant.cfm?pid=607&step=4
$28.95
Old Nov 10, 2003 | 09:36 AM
dj5's Avatar
dj5
$28.95
I bought two of the fumotovalves. One for my 02 TL-S and the other for my wife's 01 Odyssey.
I will be changing the oil on the Odyssey next weekend and will install the first one then.
Should make oil changing easier and cleaner.
Mobil 1 5W-30 and K&N HP1004 oil filters.
Old Nov 10, 2003 | 09:59 AM
Caddy©'s Avatar
Did they send you the "extension" piece ??
Old Nov 10, 2003 | 07:16 PM
Allout's Avatar
Blown is Best
Check out the listing for the Accord V6 - 99 thru 2002 should do.
Old Nov 11, 2003 | 05:30 AM
dj5's Avatar
dj5
Yes, I ordered the extension pieces for both.
Old Nov 11, 2003 | 06:15 AM
Red-CL's Avatar
Doin' da crack shuffle
Is there a picture of it anywhere?
Old Nov 11, 2003 | 10:04 AM
fender4's Avatar
Call me crazy but I just order one of these,,, I change my oil every 4.5 months (every 10k miles) and this thing looks interesting.
Old Nov 11, 2003 | 10:23 AM
tdtsai's Avatar
I have a topsider for several years already. It's a clean operation to suck out the oil. I am not familiar with the fomoto valve, but I think you still have to raise the car to get under it to drain the oil. Right? Not with the topsider
Old Nov 11, 2003 | 07:33 PM
AcuraTLSFan's Avatar
Registered Member
I have a lowered (low) TL-S and i didn't want to get the fumotovalves because it sticks out a bit and i was worried that i might break it off over a dip or speed bump... So i the fram one
Fram has no application for our car...but i the 14 mm on fits. I got it, easy to install. The fram one is cheaper then the fumoto one, i think you can get it from walmart for ~$20.
My review is...i don't really like it. Since my car is lowered, i still have to jack up my car. It creates less of a mess, but sometimes it's more of a hassle...sometime it's hard to unscrew the cap...so i just got mad and just removed it and install the stock bolt.
The valve takes forever to drain...the takes about 2-3x longer to complete drain compared to no valve. But if your car isn't lowered and you can fit under your car while doing your oil change, i think it might be worth it.
MetalGearTypeS
Aug 29, 2016 08:28 PM
hpfiend
Sep 27, 2015 06:59 AM
Rcelestino93
Sep 23, 2015 10:01 PM
STL TL-S
Sep 23, 2015 08:52 PM
Padre
Sep 19, 2015 09:08 AM
