fog lights
Old Aug 19, 2002 | 08:54 AM
tsjet's Avatar
7th Gear
fog lights
Does it make a difference if use the polarg m6 or the piaa replacement bulbs? Thanks.
Old Aug 19, 2002 | 09:03 AM
23wt's Avatar
Mugen Racing Team
for the 18W it only makes it bright during the night... it "looks" like a fog light, but still a useless roadlamp... and may cause burning in the housing depending on how often you have them on....
Old Aug 19, 2002 | 09:32 AM
CO-CL-S's Avatar
Re: fog lights
No difference..
Old Aug 19, 2002 | 01:24 PM
gto2050's Avatar
Someday pigs WILL fly!
It DOES NOT cause burning. The white discoloration above the bulb is there from the factory. It may looks suspicious but it comes that way brand new. I just replaced one of mine and that's the way it came.
Old Aug 19, 2002 | 01:26 PM
gto2050's Avatar
Oh yeah.... the PIAA 18W bulbs (19224) are the same size and color as the POLARG M6. I have one of each currently burning. They are three times brighter than the stock lame yellow bulb. None of us changed them for brightness but we changed for color matching.
Old Aug 19, 2002 | 10:47 PM
tsjet's Avatar
7th Gear
Thanks for the help.
Old Aug 20, 2002 | 09:09 AM
23wt's Avatar
Mugen Racing Team
well to say honestly... i've been using mine for almost half a year and its still the first pair and i don't find any burning either..... it was said to burn from some threads i read before....
Old Aug 21, 2002 | 01:28 AM
gto2050's Avatar
The so-called burning that people were reporting is a white area above the bulb. I looked at mine after the reports started coming in and I saw a white circle about 1/2 inch in diameter. I thought it was burned as well. Later I had a lens break and I had to buy a whole new assembly. When I opened the package to install it, there was more "burning" after complete non-use than the one that was in there for 2 years. So I have to assume that there is no "burning". I put a new one in and it's staying!
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
