A few known problems with CL-S
Old Jan 22, 2002 | 01:54 PM
alient's Avatar
hey all:
I know that some of you have these problems and found the fix for them. Can someone just tell me what the fix are so I can be more prepared when I take the car to dealer to fix?
1) uneven exhaust pipe
2) VSA indicator light is dimmly lit at nite after driving for a while.
The bottom of the triangle looks sort of orange and I know someone mentioned this before. It is sort of a bleed over light. Only happens after the car is on for a while.
3) squeaky door handle. When opening the door from the inside, the unlatch mechanism in the door squeaks. I am sure this can be fixed by some simple WD-40. But the squeak is inside the door panel, so anyone know where the squeak is coming from? And why doesn't it happen when opening the door from the outside?
4) slight moisture in the head light. Nope, the car is stock. I didn't try to open up the casing to do anything funky.
Thanks for the help!
Old Jan 22, 2002 | 02:14 PM
patsmere's Avatar
Any Lady Want One??? :-P
1.) an uneven muffler can be fixed by checking out Chod's FAQ
2.) not sure
3.) not sure
4.) can be fixed under warranty from the dealer
hope this helps somewhat
Old Jan 22, 2002 | 02:53 PM
CL Type Slim's Avatar
The Slim Member
I recently noticed that my VSA is dimmely lit when I have my headlights on. Probably just happened within the last month. Had the car for about 9 months and was built in Jan 2001. Got to bring the car into the dealer to deal with that and several other stuff.
Old Jan 22, 2002 | 04:43 PM
craigyg69's Avatar
I don't know why everyone makes such a big deal about the light bleeding over into the VSA triangle. It's just light, guys.
Old Jan 22, 2002 | 05:26 PM
foe's Avatar
foe
i bet you wont be saying that when your little light is bleading like a crazy mofo
Old Jan 22, 2002 | 05:36 PM
CO-CL-S's Avatar
I think both he and I will. Until my eyesight goes completely..YMMV
Old Jan 23, 2002 | 12:02 AM
craigyg69's Avatar
Mine bleeds.. I don't mind it.
Old Jan 23, 2002 | 12:22 AM
astro's Avatar
Community Architect
robb m.
I think most will bleed a bit, and I doubt that the dealer is going to do a service on it!
to properly fix it I think it would take pulling the dash out, not a nice job!
Old Jan 23, 2002 | 01:01 AM
Chung S's Avatar
I got the squeeky door handle, for a while at least, then it just went away after a month
Pham Alvan
May 18, 2021 06:48 AM
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
