Fawk, collision put in wrong spring
:o
when they replaced the strut on the front passenger side it came w/ a new stock spring, so they installed it not knowing that the spring they took out was an eibach, threw the eibach spring away..
i get a call today from the collison today that my car is finally ready, been almost 2 months, so i'm all excited to get my car and i pull in and notice that the front seems a lil high, looked soo fucked up
guy ordered a new eibach pro-kit and we'll go from there, i dunno how the fuck they aligned the car with 2 diff. springs
dont you guys think they should change both of the front springs? cause he said they are only gonna change the passenger side, then the drivers side would be settled and the new spring on the other side...does it make that bif of a difference??
You probably need a qualified metallurgist to answer this one. Properly designed springs should not fatigue unless severely abused. I mean, thats the whole design theory behind a spring, if you think about it.
I had a one side collision and they only replaced that tire on the side that was hit. ALso the same for the suspension, so the car still likes to float in that direction at times.
I changed all the tires soon after this, and it still goes a little to that side, not as bad though..
You might want to check with Eibach about this.
Some vendors will provide a “set” of "matched" left and right springs. I don’t know about Eibach.
Eibach makes springs of the highest quality -- and do provide to lots of motorsports teams -- so, you are probably going to have very little spring sag. However, it couldn't hurt to call them…
You will then know everything you need to know about what they should replace.
Tech support: 909.256.8300 (Now closed for the day)
http://www.eibach.com/cgi-bin/start....ach/index.html
BTW, you wonder about people doing body work that don't notice the "details" - hey?
Originally posted by darrinb
i guess, will see how it drives
thanks for the help eric
cycdaniel
12-17-2019 10:58 AM
jmoney2001
08-12-2019 06:23 PM
1fatcrxnem1
22
06-01-2018 01:23 AM
