Engine Light
Old Apr 8, 2004 | 06:21 AM
1killercls's Avatar
GEEZER
Engine Light
My Engine Light went on yesterday and didn't turn back off untill I was driving to work this morning. The manual says it is an Emission problem...and I did notice that the idle speed is very low. Think I may take it to the dealer
..and NO it is not the Maint. Required Light. It is the little engine light.
Ideas????
Old Apr 8, 2004 | 06:32 AM
liloj's Avatar
i like orange juice
have you filled up with gas recently..mine always comes on...cause i dont tighten my gas cap all the way ...i just reset it....
Old Apr 8, 2004 | 06:33 AM
liloj's Avatar
i like orange juice
just reset it..if it comes on again..then you have a prob.....
Old Apr 8, 2004 | 06:36 AM
1killercls's Avatar
GEEZER
This is not the light that can just be RESET.:o
Old Apr 8, 2004 | 07:04 AM
GreenMonster's Avatar
Even if you diconnect the battery It's not the maintanance light, so you should get the car checked out.
Old Apr 8, 2004 | 07:12 AM
1killercls's Avatar
GEEZER
yea..I am taking it in this afternoon after posting..er I mean work..
Old Apr 8, 2004 | 08:04 AM
typeR's Avatar
yes you can reset it...if you just pull the - on the battery the stored CEL will be cleared....my cars at crown right now....and i have a nice '04 tl loaner
Old Apr 8, 2004 | 09:38 AM
1killercls's Avatar
GEEZER
I know I saw it this morning....They didn't have a loaner till this afternoon....
I am having a couple other issues checked out too...
Old Apr 8, 2004 | 09:50 AM
typeR's Avatar
...i am also having a check engine light...it read knock sensor so we'll see how that pans out...plus two new half shafts and maybe a couple motor mounts and a drivers side heater pad
Old Apr 8, 2004 | 09:52 AM
1killercls's Avatar
GEEZER
WOW Half Shafts aren't cheap...is that because of the added HP you have???
Old Apr 8, 2004 | 10:11 AM
typeR's Avatar
not sure....it's warranty work...it's really bad inner CV's but it turns out to be cheaper to replace the entire hafl shaft than do the work on just the CV...this could also be just a contamination problem steming from a replaced transmission
Old Apr 8, 2004 | 10:46 AM
1killercls's Avatar
GEEZER
Understand..I am having them check my trans out again too. 2nd-3 rd shift is a little to mushy for my tastes (second Trans)...well good luck with all the work.
Old Apr 8, 2004 | 11:02 AM
lead_sled_dog's Avatar
Back to Four Doors
I just had the PCM installed on my CLS and the 2-3 shifts are definitely faster and less "mushy."
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
