ECU for transmission?
Old Jun 23, 2011 | 07:56 PM
ironsurfer129's Avatar
CL-Pride
Is there an ECU for transmission? I feel that the shifting point and such is different from my previous transmission after the swap. It shifts at unexpected point which makes it "un-smooth" when I drive. If there is an ECU, i am assuming it has adapted to the previous driver?
Old Jun 24, 2011 | 08:51 AM
harvthesecond's Avatar
Yes the transmission is electronically controlled. The TCU(trans control unit) is separate from the transmission, just like the ECU is separate from the engine. So if you just swapped transmissions you should still have your TCU in place. It is possible that the TCU lost your style of driving while the battery was disconnected for the swap and probably needs to relearn how you drive. On a car as bad ass as the CL I'd think its starting point would be pretty smooth but I could be wrong.
Old Jun 24, 2011 | 02:30 PM
Sonor Kid 2's Avatar
When the dealer replaces your tranny I've been told they are also swapping the TCU with a bit less agressive shift points....
Old Jun 26, 2011 | 11:17 PM
aznboi2424's Avatar
Yup, all dealership replaced transmissions come with a TCU replacement as well.
TypeS860
Jan 10, 2026 11:11 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
Skirmich
Oct 1, 2015 12:59 PM
hashbrown
Sep 29, 2015 12:13 PM
malvothegreat
Sep 29, 2015 12:38 AM
