Ebay catch can review and somewhat of an install guide
Old Nov 11, 2012 | 01:23 PM
jaeravenal's Avatar
Membistered Regember
There are many threads explaining the importance of an oil catch can (thank you OPs to the threads)
https://acurazine.com/forums/2g-cl-2001-2003-50/importance-oil-catch-can-717397/
In a nutshell, when the pcv and other vaccuum systems suck out the gases from the crankcase and dumps it into the intake to be burned off,
Oil might be sucked in as well.
The benefits of a catch can is to catch the oil so it doesnt get sucked in through the intake manifold and possibly contaminate or have build up inside, nor the oil wont burn through the exhaust.
This can result in a cleaner intake manifold.
Being cheap i bought the EBAY universal catch can for under 20 bones.
Functionality:9/10
price:10/10
build quality:7/10
Here is what it comes with from the TL side of the forums (thanks OP)
https://acurazine.com/forums/2g-tl-1999-2003-98/oil-catch-can-diy-693521/
first picture.
With my install, i only used the ring clamps the catch can and the felt gaskets and the blue tube.
The other parts are for mounting, but i couldn't figure out how to mount it with those.
Mounting is all custom, and you can use your own tubing and make it all custom but i'm cheap so i utilized the parts it came with
Here is my ebay catch can installed to the left of my G-take (ghetto intake)
Here is a diagram to where each hose goes
I have chose to mount it using the big clamp to wrap around the catch can
and a 3/8 hose clamp clamped to the strut brace/bar thing.
As you can see, one tube goes to back of the valve cover
and one goes into the pcv valve
***Before installing you might want to untighten the screws on top and add the gaskets included or RTV sealant for 100% sealingness so there will be no air leaks. Slap those things on then retighten (i believe it is a hex screw thing like H10, i'm not sure i forgot) Also tighten all other components as they might come loose.
Here is more pictures of where the hoses lead up to
Here is the PCV location (the bottom blue hose) (simply unhook the existing tubing and plug up the pcv with the blue hose)
Here is the location behind the left of the valve cover (next to the top most left bolt that holds on the plastic valve cover dressing engine thing VTEC black plastic)
Simply remove the tubing that is there as well and connect the other blue hose
Now simply connect the blue tubes to the catch can and tighten them down with the clamps, make sure the other ends are clamped down as well using the existing tubing clamps or by using the clamps off the other parts included with the ebay catch can that are not being used.
Then you mount it wherever you want.
If you use my method of clamping it down to the strut bar
make sure you cut the tubing precisely as there might not be enough tubing for both routes.
Enjoy cheap goodness for your engine!
Now being this is cheap, there are some drawbacks.
Here is a picture explaining why.
THe holes from the tubes are so close together than oil might be sucked back in by the other tube
There was an awesome post somewhere on here that i cannot find
or maybe it was on a hondatech or teamintegra forum i just can't find it but the guy cut it in half put a divider and jb welded it back together to ensure that the oil being caught didn't get sucked back into the intake
The best way i can explain it is this
You cut it in half, then add a metal divider of some sort in between the two holes, ensuring the oil drops down and not sucked into the other hole. Just JB weld everything back
Though this has been of concern, i have not visually seen oil into the other tubing so far. If i do see oil being sucked into the other blue tube (you can just see it changing color, the other tube should have some oil residue which indicates that oil is indeed being routed out into the can) i will open her up and do those changes. After about a week of driving with the catch can, there is already about 1oz of oil inside the can.
HoAp DIs Halps, and enjoy a cheap DIY project to improve the health of your car
Inappropirate smiley insertion:: band::ministe r:
Old Nov 11, 2012 | 02:50 PM
FwC's Avatar
FwC
Nicely done and informative. Thanks.
That being said, can a mod disable this guys emoti capabilities?
Old Nov 11, 2012 | 06:20 PM
Karanx7's Avatar
Unregistered Member
Holy shit your intake is fucking ugly.
Old Nov 11, 2012 | 06:39 PM
Karanx7's Avatar
Unregistered Member
Gonna have to buy a catch can now. Damn you OP
The TL DIY link you posted has the tubing connected to the front valve cover. Any difference?
Old Nov 11, 2012 | 09:29 PM
jaeravenal's Avatar
Originally Posted by Karanx7
Holy shit your intake is fucking ugly. Gonna have to buy a catch can now. Damn you OP
Hey hey hey fuck you
J/k to each his own. being cheap has a price and that was the only color exhaust wrap i had laying around, i could go fancy and get carbon fiber sticker/vinyl material and wrap it but that = $$$
As for the front of the valve cover, i'm not too sure bro. Does the Tl have the non type s version?
I know for a fact that there are multiple locations you can install a oil catch can , i've seen people with 2 even, so it might be that the op of that thread installed it in a different location.
I only know the pcv valve location and behind the valve cover i'm sure there are more places you can install to have maximum oil catching skillz but i am not so sure as this was the easiest one i could think of
Old Nov 11, 2012 | 09:30 PM
jaeravenal's Avatar
Noooooooo! I left a disclaimer stating that it was an inappropriate smiley insertion so it should be legal. If i didn't state a disclaimer then it should be illegal!
Old Nov 12, 2012 | 10:18 AM
AnthraciteTypeS's Avatar
6mt swapped..smart
I routed mine differently, but I can't really explain right now because my skull feels like its going to implode after reading this
Old Nov 12, 2012 | 12:50 PM
FwC's Avatar
FwC
^^^lol
Old Nov 12, 2012 | 02:38 PM
Karanx7's Avatar
Unregistered Member
K I think I figured it out.
The intake pipe has a breather tube that goes to the FRONT valve cover. Air goes through there, and passes pressure through to the rear valve cover.
Then the REAR valve cover with the PCV valve sends that gas/oil mix directly into the intake manifold. You put a catch can there to filter out the oil, wohoo.
That catch can will stop most of the fluid. However, at wide open throttle the flow can reverse. This means that gas/oil will go from the FRONT valve cover into the intake. This is how the TB gets dirty (because the rear valve cover one directly puts the gas/oil into the IM, bypassing the TB).
So you have a catch can in the rear. To be extra clean, you can have one in the front. However, since we aren't Forced Induction or Direct Injection, either one should be more than enough.
Old Nov 12, 2012 | 02:47 PM
6mt swapped..smart
Ok took an advil--head feels better..I ran mine between the front vc and rear pcv, and added a vent to the can since it didn't come with one
Old Nov 12, 2012 | 02:48 PM
Karanx7's Avatar
Unregistered Member
^This is a picture of the flow during normal use. However, during WOT the flow is reversed, which causes oil to go into the intake.
Old Nov 12, 2012 | 08:30 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
you need one on the front and one on the back skip or else its not really doing the job. which is why i got 2
Old Nov 12, 2012 | 08:48 PM
jaeravenal's Avatar
This what i was thinking about, i thought it would be redundant but what Karanx7 explained i will be going with 2 as well. better to do the job right than half assed >
For the front Valve cover i believe it will be as simple as
front valve cover -> tubing -> oil catch can ->exit through other tube -> tube into intake
at least for j32a2's
Old Nov 12, 2012 | 11:09 PM
oh yea its easy. mounting it i found was the hardest part. i didnt wanna ziptie it
Old Nov 14, 2012 | 07:57 PM
aznboi2424's Avatar
I have a catch can for the rear cover and it catches a surprising amount of oil. I don't drive the car hard or anything. If you open your intake manifold up, there will be pools of motor oil inside.
Old Nov 14, 2012 | 09:07 PM
yea its a bad design for sure, it just harbors oil in it and has no where to go
Old Nov 15, 2012 | 01:08 AM
azeezp13's Avatar
shifting at 7k
What negatives could happen with all the oil build up in the intake manifold?
Old Nov 16, 2012 | 05:42 AM
civicdrivr's Avatar
Fouled plugs, coated pistons and valves, poor combustion. Carbon build up kills gas mileage as well as performance.
Old Nov 16, 2012 | 08:33 AM
but most importantly it looks ugly when u pull the manifold apart!
Old Nov 16, 2012 | 07:24 PM
OperationDarkie's Avatar
Ultra Negro
I am just curious, hasn't there been tons of posts about DIY catch cans on this website already???
Old Nov 16, 2012 | 07:55 PM
aznboi2424's Avatar
Probably. OP refers to one in the first post of this thread.
Old Nov 16, 2012 | 11:40 PM
jaeravenal's Avatar
Yes turbo negro, i linked some of them in my opening post,
BUT
I haven't seen one specifically for the j32a2 engines more specifically for the 2001-2003 Acura Cl.
They were mostly for the TLs
or Non type s CL ( and TL)
j30? i believe
Old Nov 16, 2012 | 11:42 PM
jaeravenal's Avatar
Coudlnt' say it better than civicdrvr and clsprogression 01
sludge build up causing decrease performance/ mpg
and your intake manifold will be all oily brown and possibly have carbon (black) deposits in it, imagine all that gunk blocking the flow of air!
Old Nov 17, 2012 | 12:25 AM
civicdrivr's Avatar
Did you just call OperationDarkie "turbo negro"????
Old Nov 17, 2012 | 05:31 PM
i will get a pic of my engine bay with both catch cans on my 01 cl-s to put a stop to all this madness.. and YALL gonna be jealous with my fully aluminium red annodized simota catch canz.... mmmhmmmmmmmmmm lol
will post it up monday hopefully.
Old Nov 17, 2012 | 08:56 PM
jaeravenal's Avatar
Haha yeah, cause his registered member thing is "ultra negro"
and i just called him turbonegro cause it's a band
Old Nov 17, 2012 | 09:04 PM
jaeravenal's Avatar
How much did you spend on a catch can
Old Nov 19, 2012 | 03:34 PM
aznboi2424's Avatar
BUT
j30? i believe
But the pipe routing should be identical for the 2G CL/TL regardless of engine.
Old Nov 19, 2012 | 04:50 PM
lol it as like 80 each... i bought one.. and then thought to myself wtf are u doing u goof.. cause there are 2 sides to the motor.. and so i bought another.. so like 170s..
looks nice 1 and will keep motor wayyyy cleaner in my opinion 2..
still need to get that picture posted up gentlemen.. if u can believe it i do not have a camera not even one on my phone cause it's a sonim xp1300 or w/e and does not come with one..
so when i am around a friend who has camera i will get that pic
Old Nov 20, 2012 | 01:13 AM
jaeravenal's Avatar
haha yeah does look fancy! I bet it isn't cheapo made like the ebay one, the holes are close together where the tubes enter and there isn't anything to divide it so it might be getting sucked back into the engine, so far i haven't notcied that though and there is some nice black oil inside
lol you driving a fancy CL and your phone don't have no camera
Old Nov 20, 2012 | 01:15 AM
jaeravenal's Avatar
Looked different in the other forums because i think they used a different route of tubing i didn't understand, and also under the throttle body and the coolant tubes looked so different
I learn slowly but surely
Old Nov 27, 2012 | 12:32 AM
jaeravenal's Avatar
Update: Oil residue is seen going through the other line -_-
cheap you get what you pay for..
but low and behold! I have a theoretical solution!
I will simply unbolt the top part and hot glue/ epoxy a slurpee straw (or whatever size will fit) into the hole that sucks in the oil, this will insure that the oil will drop down to the bottom, and not just get sucked into the other hole.
CHeap ftw
Old Nov 27, 2012 | 10:47 AM
brian6speed's Avatar
Lone Wolf
I would recommend a catch can to everyone even a N/A stock engine. You would be amazed at how much oil I removed from mine just after a few thousand miles.
Cheap ftl, you get what you pay for. Might as well make one from a coke can. Those blue hoses look awful too.
I made sure the one I bought was baffled, and it has steel wool mesh in it to help. It also has a drain tube at the bottom to easily remove the oil.
Most catch cans you can buy are not baffled, even the name brand expensive ones.
I also wanted one without a filter on it dispersing oil vapor all over my engine bay.
If you think $80 is a lot for a air/oil separator(catch can) then you will think mine is a ripoff. I paid nearly $150 for mine.
This was after 1200 miles.
Here is my universal moroso air/oil separator. I made the bracket myself by cutting 2 brackets down(oem bracket and moroso one) and welding them together.
You can't see the drain tube in the pics.
Old Nov 27, 2012 | 11:43 AM
FwC's Avatar
FwC
It's hard to tell from the pics. Just to be clear, this is an intermediary that sits between the PCV valve and wherever that tube leads?
Old Nov 27, 2012 | 12:18 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Please don't
Old Nov 28, 2012 | 01:14 PM
jaeravenal's Avatar
Please don't
Old Nov 28, 2012 | 06:55 PM
aznboi2424's Avatar
And the intake manifold.
Basically something that strains the oil from that air and collect it to be discarded.
Old Nov 30, 2012 | 08:29 AM
pics will be up tonight or tomorrow, i got a camera on ME finally LOL... just been super busy with school, essays, work, partying... u KNOOOOO
cycdaniel
Dec 17, 2019 10:58 AM
bailey24
Nov 21, 2015 08:43 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
lland
Oct 4, 2015 04:47 PM
nuldabz
Sep 3, 2015 05:49 PM
