driving light replacement
OK, so I'm new to this and not really all that mechanically savvy. So can anyone out there tell me how to replace the driving lights on my '01 CL? Probably very simple, but......
What to do, what to think
you mean the HID bulbs or High beams? if the HID's D2R's you could replace them to an 6000k D2S....here check out this link:
http://www.hid-online.com/hidonline/..._D2R_6000k.htm
He means the road lamps bubs, the fog lights...
Check this thread for details on replacing the bulbs
http://wizardsworks.org/chod/acura/m6/
A senior member
You are so lucky because I just replaced both of mine this weekend
Both lens were cracked due to the stupid location of the lights. You can remove the lighting unit and change the bulbs without getting underneath the car
I learned that after I did the first one. Here is how:
1. use a long handle phillip screwdriver, find the notch on the front grill next to the light, stick the screw driver in the notch(gap) and try to stick it into the hole where the screw is. This may take a few trial and error to find that hole because you cant see it, you have to do it by feel, once the driver is in the hole, turn counter clockwise to loosen the screw, you can use a flat blade on the wider side of light and pry it out once the screw is completely loosen. The screw will be loosen but will not drop out due to the good design. Take the unit out and change the unit/ or the bulb as you wish.
Remember, you don't have to get under the car to do it!!! The owner manual stated to get under the car, but that's the wrong way and took a lot of time.
King of the Road has it. Idiot proof explanations are exactly what I need.
The Polarg bulbs look fantastic, any suggestions as to where I can purchase?
Pimp Daddy Gold
Thanks for the help! I've already sent off an email to autocarparts to purchase.
This is my first try at getting help on this forum and have to say I'm very impressed with everyone's willingness to assist.
YOU GUYS ARE GREAT!!!
is there any major difference between the piaa or polarg?
also my rear reverse light went out. what bulb do i need to get n where can i get it? sorry if this deviates from the original post but just looking for info. thx for the help in advance.
If you just want the stock replacements for any bulbs try the dealer. Mine replaces lights for free.
Keep in mind, my local Acura dealer could just be a really good one. I have read on here where some people have had nothing but bad experiences with their Acura dealers. I guess I am just lucky.
i just changed mine yesterday, if your arms are small enough all you gotta do is reach under and go inbetween the plastic cover and reach up. then you turn it counter clockwise and bring the light down and change the bulb
gto2050's right on. I first replaced with the stock bulb and the yellow looks like crap. I just ordered the Polarg's and am looking forward to getting them in.
rog2961 must have damn small arms, no way mine would fit in there.
Also noticed the other night, driving in the rain, a V-shaped light projection going straight up from each headlight. Anyone else ever notice this?
Beware of leakage
Someday pigs WILL fly!
Eurotrash
There is a TSB (can't remember number) for road lamp bulbs burning out prematurely, so if you're still under warranty the dealers should replace them with updated bulbs for free. Mine did when I mentioned the TSB. But they still serve no purpose except to look dim and cheap...
From searching on here, it seems the consensus is that larger wattage bulbs can melt the housing in addition to being difficult to remove....
But I wouldn't mind trying the PIAA 19173 bulbs. They are yellow and the correct wattage (5W). Has anyone tried these?
Some day when I have nothing to do, I'll look into wiring the road lamps into the side marker circuit as others on here have done, so that at least they can be used as daytime running lights....
mada51589
05-03-2022 08:54 PM
wusty23jd
09-24-2015 11:41 AM
