Driver's side window is "sticking" on hot days
Is anyone else having this problem...if so what can I do about it? On really hot days when I try 2 use the auto down feature, the window stops and I have to hit the button a couple more times to get it down.
6 speed...
my car has the same issue. it only happens with the interior gets warm from the sun ('bout that time of year again).
prolly should have it looked at, but I'm too lazy.
Originally posted by DarkSithCL
Could be...maybe when it gets too warm...only got 37K on the CLS...need to take it to the dealer maybe...thanks for the reply Doom878!!!!
Sweet as Gold
It's normal...about the only thing you could do is replace the window run channel...but it will happen again!!so if it really bothers u...spray some silicone spray inside the run channel and move the window up and down to lubricate it.
Sweet as Gold
the motor doesn't stop it...the auto-down feature is controled by a small unit. It's a safety feature that stops the motor from moving down just ncase u might be crushing something or whatever. Just lube up the run channel so it doesn't become so sticcky when it gets hot.
I agree with CLpower, get some silicon spray. The same thing happened with my old CRX. If you don't lube the edges ever now and then it will cause bigger problems in the long run.
acura_dipset_tl
01-01-2016 03:02 PM
ahsm
09-09-2015 08:35 AM
