Driver's Side Window
Old Sep 23, 2003 | 06:07 PM
AsianDDRManiac's Avatar
My Driver's Side window fell and I don't know how to fix it
The motor still works, its just that the window doesn't catch and its stuck inside the door~
anyone have a clue to how to fix it?
Old Sep 23, 2003 | 08:28 PM
Ant7701's Avatar
Sweet as Gold
replace your driver's side window regulator assy...you must remove the door panel...then remove the regulator while holding the door glass in the fully closed position...once you remove the bolts for the regulator...the glass will slide up. It's pretty simple.
Also if it's not an actual problem...like a faulty part or something...then take off the door panel and window run channel and you should be able to free it up!!
Old Sep 23, 2003 | 08:45 PM
Titand19's Avatar
East Coast Boost.!
Ant works at acura what do you expect.
If you got common sense, this is what you do. take off the door panel, unbolt the track, and slide the window back in.
Sorry ant, I know what you're saying, but you know the guys on this board.
Old Sep 24, 2003 | 07:09 AM
bigman's Avatar
'Big Daddy Diggler'
I'd just take the inner door panel off, take off the track and line the window back up. Or if you are not mechanically inclined, just take the car to the dealer for a quick warranty fix.
Old Sep 24, 2003 | 07:46 AM
Jens H.'s Avatar
retired
Sounds like the window regulator has a faulty cable on it .Nothing you can do but replace it .Your dealer probably stocks them ,I know we do here at PAA .This is not an uncommon thing to happen so even if your car is out of warranty they may goodwill it for you .
Jens
Old Sep 24, 2003 | 07:49 AM
zamo's Avatar
Houses Won't Depreciate?
TX man, heat is the problem. Those window regulator failures are common in many brands (BMW is one of the most suffering).
Old Sep 28, 2003 | 06:11 PM
thanx guyz~ i'll see if it works out or not! i'll probably make some stupid mistake and end up with no window, and no door pannel
Old Sep 28, 2003 | 06:51 PM
YuppieCL's Avatar
Moderator Alumnus
take it to the dealer
jblessing
Aug 8, 2018 09:43 PM
acura_dipset_tl
Jan 1, 2016 03:02 PM
sockr1
Oct 1, 2015 01:31 AM
PortlandRL
Sep 14, 2015 12:01 PM
ahsm
Sep 9, 2015 08:35 AM
